RFID Reader — Parallax Forums
RFID Reader
Rvo11Rvo11 Posts: 4
edited 2010-05-24 23:01 in BASIC Stamp
Right now My project partner and I are trying to create a program where if we bring a certain card up to the reader it will read the entire code and make a decision at the end of the byte and tell us what it is and what number we installed it to remember. At the moment we have created a program that can show the memorization of the cards for a certain number, but can't turn off the LED DIGIT counter. Can you come up with a program that can incoporate all of this?
    edited 2010-05-19 20:16
    Heck yeah, we can!
    More importantly, can YOU?
    You'll need to describe what you want more thoroughly, post your code thus far, and identify what it's not doing for any useful help.
  • Rvo11Rvo11 Posts: 4
    edited 2010-05-20 20:50
    ' File....... RFID.BS2
    ' Purpose.... RFID Tag Reader / Simple Security System
    ' Author..... (c) Parallax, Inc. -- All Rights Reserved
    ' E-mail..... support@parallax.com
    ' Started....
    ' Updated.... 09 SEPT. 2005
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    [noparse][[/noparse] Program Description ]
    ' Reads tags from a Parallax RFID reader and compares to known tags (stored
    ' in EEPROM table). If tag is found, the program will disable a lock.
    [noparse][[/noparse] Revision History ]
    [noparse][[/noparse] I/O Definitions ]
    Enable PIN 0 ' low = reader on
    RX PIN 1 ' serial from reader
    Spkr PIN 2 ' speaker output
    Latch PIN 3 ' lock/latch control
    [noparse][[/noparse] Constants ]
    #SELECT $STAMP
    #CASE BS2, BS2E, BS2PE
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    TMidi CON 12
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    TMidi CON 60
    T38K4 CON 45
    #CASE BS2PX
    T1200 CON 3313
    T2400 CON 1646
    T4800 CON 813
    T9600 CON 396
    T19K2 CON 188
    TMidi CON 108
    T38K4 CON 84
    #ENDSELECT
    SevenBit CON $2000
    Inverted CON $4000
    Open CON $8000
    Baud CON T2400
    #SELECT $STAMP
    #CASE BS2, BS2E
    TmAdj CON $100 ' x 1.0 (time adjust)
    FrAdj CON $100 ' x 1.0 (freq adjust)
    #CASE BS2SX
    TmAdj CON $280 ' x 2.5
    FrAdj CON $066 ' x 0.4
    #CASE BS2P
    TmAdj CON $3C5 ' x 3.77
    FrAdj CON $044 ' x 0.265
    #CASE BS2PE
    FrAdj CON $0AA ' x 0.665
    #CASE BS2PX
    TmAdj CON $607 ' x 6.03
    FrAdj CON $2A ' x 0.166
    #ENDSELECT
    LastTag CON 5
    #DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have SPRAM?
    [noparse][[/noparse] Variables ]
    #IF __No_SPRAM #THEN
    buf VAR Byte(10) ' RFID bytes buffer
    #ELSE
    chkChar VAR Byte ' character to test
    #ENDIF
    tagNum VAR Nib ' from EEPROM table
    idx VAR Byte ' tag byte index
    char VAR Byte ' character from table
    pinCounter VAR Nib
    OUTH = %00000000
    DIRH = %11111111
    [noparse][[/noparse] EEPROM Data ]
    Tag1 DATA "28001D66F5" ' valid tags
    Tag2 DATA "3C0073E205"
    Tag3 DATA "1700800E32"
    Tag4 DATA "170081B810"
    Tag5 DATA "24008CEADA"
    Name0 DATA "Unauthorized", CR, 0
    Name1 DATA "Tag 1 (50mm round)", CR, 0
    Name2 DATA "Tag 2 (Key Fob)", CR, 0
    Name3 DATA "Tag 3 (Credit Card 1)", CR, 0
    Name4 DATA "Tag 4 (Credit Card 2)", CR, 0
    Name5 DATA "Tag 5 (25mm round)", CR, 0
    [noparse][[/noparse] Initialization ]
    Reset:
    HIGH Enable ' turn of RFID reader
    LOW Latch ' lock the door!
    [noparse][[/noparse] Program Code ]
    Main:
    LOW Enable ' activate the reader
    SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
    #ELSE
    SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
    #ENDIF
    HIGH Enable ' deactivate reader
    Check_List:
    DO
    FOR tagNum = 1 TO lasttag ' scan through known tags
    FOR idx = 0 TO 9 ' scan bytes in tag
    READ (tagNum - 1 * 10 + idx), char ' get tag data from table
    IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table
    #ELSE
    GET idx, chkChar ' read char from SPRAM
    IF (char <> chkChar) THEN Bad_Char ' compare to table
    #ENDIF
    IF (tagNum = 1) THEN
    OUTH = %10000100
    DEBUG "Welcome Raymond" '1
    PAUSE 1000
    ELSEIF (tagNum = 2) THEN
    OUTH = %11010011
    DEBUG "Go Away Sarafina!" '2
    PAUSE 1000
    ELSEIF (tagNum = 3) THEN
    OUTH = %11010110
    DEBUG "Nice Hair Josiah!" '3
    PAUSE 1000
    ELSEIF (tagnum = 4) THEN
    OUTH = %10110100
    DEBUG "Failure is NOT an Option!" '4
    PAUSE 1000
    ELSEIF (tagNum = 5) THEN
    OUTH = %01110110
    DEBUG "Hunter is the Winner!" '5
    PAUSE 1000
    ENDIF
    NEXT
    DIRH = %00000000
    GOTO Tag_Found ' all bytes match!
    Bad_Char: ' try next tag
    NEXT
    Bad_Tag:
    tagNum = 0
    GOSUB Show_Name ' print message
    FREQOUT Spkr, 1000 */ TmAdj, 115 */ FrAdj ' groan
    PAUSE 1000
    GOTO Main
    Tag_Found:
    GOSUB Show_Name ' print name
    GOTO Main
    LOOP
    END
    [noparse][[/noparse] Subroutines ]
    ' Prints name associated with RFID tag
    Show_Name:
    DEBUG DEC tagNum, ": "
    LOOKUP tagNum,
    [noparse][[/noparse]Name0, Name1, Name2, Name3, Name4, Name5], idx ' point to first character
    DO
    READ idx, char ' read character from name
    IF (char = 0) THEN EXIT ' if 0, we're done
    END
    DEBUG char ' otherwise print it
    idx = idx + 1 ' point to next character
    LOOP
    RETURN
    edited 2010-05-21 02:33
    Where in the code do you have a problem? How do you have things connected to the stamp (what pins go where)? What are you expecting and what are you getting instead?
    - Stephen
    edited 2010-05-21 21:05
    The problem is in the program code where i can't make certain i.d tags to come up with the numbers i want and then turn off and got into a loop where i can do it again. I have the Digit LED counter connect from pin 15 down to pin 8 and my RFID reader is connect to pin 0 and 1. What i was expecting to come out was to write in a seperate sub category in the program code and have the I.D card showned and have it display a certain number and then create a loop where it goes through all that process again. What i get is that it makes it decision every byte it goes through instead of going through it all then making a decision. If you can make a program that can do all this please post it.
    edited 2010-05-22 00:26
    Take a look at this it·may help you
    ' File.......  Soldering Station Time Controller.bs2
    ' Purpose...  To use RFID Card Reader and DS1302
    ' Author....  Sam
    ' Started....
    ' Updated.... 6-01-06
    ' I Want to Thank  Chris Savage, Jon Williams ,Tracy Allen and PJ Allen
    ' For Helping understand how To write these Card routines and the Time Routine
    ' -----[noparse][[/noparse] Program Description ]---------------------------------------------
    ' To use RFID Card Reader and DS1302 With a BS2
    ' To use differnet Card for differnet amount of Time
    ' EXAMPLES
    ' Card # 1 is fot 15 Minutes and 00 Seconds
    ' Card # 2 is fot 30 Minutes and 00 Seconds
    ' Card # 3 is fot 59 Minutes and 59 Seconds
    ' Card # 4 is fot 01 Hour and 59 Minutes and 59 Seconds....... Coming Soon......
    '   E-mail..... [url=mailto:support@parallax.com]support@parallax.com[/url]
    '   Started....
    '   File...... DS1302_Demo.bs2
    '   Purpose... Demonstrate The DS1302 Clock
    '   Author.... Chris Savage -- Parallax, Inc.
    '   E-mail.... [url=mailto:csavage@parallax.com]csavage@parallax.com[/url]
    '   Started...
    '   Updated... 10-09-2005
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
    DataIO          PIN     1                      ' DS1302.6
    Clock           PIN     0                      ' DS1302.7
    CS1302          PIN     2                      ' DS1302.5
    Enable          PIN     8                      ' low = reader on
    RX              PIN     7                      ' serial from reader
         'Not Used                                 ' speaker output
    Relay           PIN     10                     ' control relay
    Invaild_Card    PIN     15                     ' Invaild_Card Led
    card15          PIN     14                     ' 15 Min Card
    card30          PIN     13                     ' 30 Min Card
    card60          PIN     12                     ' 60 Min Card
    tick            PIN     11                     ' program running
    ' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
    #SELECT $STAMP
        T1200       CON     813
        T2400       CON     396
        T4800       CON     188
        T9600       CON     84
        T19K2       CON     32
        TMidi       CON     12
        T38K4       CON     6
    #ENDSELECT
    SevenBit        CON     $2000
    Inverted        CON     $4000
    Open            CON     $8000
    Baud            CON     T2400
    #SELECT $STAMP
      #CASE BS2, BS2E
    #ENDSELECT
    LastTag         CON     3
    WrSecs          CON     $80                       ' Write Seconds
    RdSecs          CON     $81                       ' Read Seconds
    WrMins          CON     $82                       ' Write Minutes
    RdMins          CON     $83                       ' Read Minutes
    WrHrs           CON     $84                       ' Write Hours
    RdHrs           CON     $85                       ' Read Hours
    CWPr            CON     $8E                       ' Write Protect Register
    WPr1            CON     $80                       ' Set Write Protect
    WPr0            CON     $00                       ' Clear Write Protect
    WrBurst         CON     $BE                       ' Write Burst Of Data
    RdBurst         CON     $BF                       ' Read Burst Of Data
    WrRam           CON     $C0                       ' Write RAM Data
    RdRam           CON     $C1                       ' Read RAM Data
    Hr24            CON     0                         ' 24 Hour Mode
    Hr12            CON     1                         ' 12 Hour Mode
    ' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
    index           VAR     Byte                        ' Loop Counter
    reg             VAR     Byte                        ' Read/Write Address
    ioByte          VAR     Byte                        ' Data To/From DS1302
    secs            VAR     Byte                        ' Seconds
    secs01          VAR     secs.LOWNIB
    secs10          VAR     secs.HIGHNIB
    mins            VAR     Byte                          ' Minutes
    mins01          VAR     mins.LOWNIB
    mins10          VAR     mins.HIGHNIB
    hrs             VAR     Byte                           ' Hours
    hrs01           VAR     hrs.LOWNIB
    hrs10           VAR     hrs.HIGHNIB
    date            VAR     Byte
    month           VAR     Byte
    day             VAR     Nib                              ' Day
    year            VAR     Byte                             ' Year
    ampm            VAR     hrs.BIT5                          ' AM/PM Flag Bit
    clockMode       VAR     hrs.BIT7                          ' 12/24 Hour Mode Bit
    ampmFlag        VAR     Bit                               ' 0 = AM, 1 = PM
    modeFlag        VAR     Bit                               ' 0 = 24, 1 = 12 (Hours)
    work            VAR     Byte                               ' Work Data
    #ELSE
    #ENDIF
    ' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
    Tag1            DATA    "04158DD890"                           ' valid tags
    Tag2            DATA    "04158DCE28"
    Tag3            DATA    "04158DCA62"
    Name0           DATA    "........STOP.........", CR, 0
    Name1           DATA    "Tag 1 (15  MIN  CARD)", CR, 0
    Name2           DATA    "Tag 2 (30  MIN  CARD)", CR, 0
    Name3           DATA    "Tag 3 (1   HOUR CARD)", CR, 0
    ' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
    Reset:
      LOW  relay                                                        ' lock the door!
    Init:
      reg = CWPr                                                       ' Initialize DS1302
      ioByte = WPr0                                                    ' Clear Write Protect
      GOSUB RTC_Out                                                    ' Send Command
    ' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
    Main:
       DEBUG CLS, CLS
      #ELSE
      #ENDIF
    Check_List:
      FOR tagNum = 1 TO LastTag                                            ' scan through known tags
          #ELSE
          #ENDIF
        NEXT
      NEXT
    Bad_Tag:
      tagNum = 0
      GOTO Routine0
    Tag_Found:
    ON tagNum GOSUB Routine0,  Routine1, Routine2, Routine3
     ' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
    Show_Name:
      DEBUG DEC tagNum, ": ", CR
      LOOKUP tagNum,
             [noparse][[/noparse]Name0, Name1, Name2, Name3], idx                                  ' point to first character
      DO
      LOOP
      RETURN
    RTC_Out:
      HIGH CS1302        ' Select DS1302
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg, ioByte]
      LOW CS1302        ' Deselect DS1302
      RETURN
    RTC_In:
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg]
      SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]ioByte]
      RETURN
    Set_Time:        ' DS1302 Burst Write
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]WrBurst]
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs, mins, hrs,
        date, month, day, year, 0]
      RETURN
    Get_Time:        ' DS1302 Burst Read
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst]
      SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]secs, mins, hrs, date, month, day, year]
      RETURN
    ' -----[noparse][[/noparse]Card's Subroutines ]-----------------------------------------------------
    ' Card # 0 is fot Unauthorized CARD
       'Unauthorized CARD Routine
        'Unauthorized CARD Led Light......
      Routine0:
       mins=$00
       secs=$00
      GOSUB Set_Time
      HIGH  Invaild_Card                                                         'Turn ON Led
      DO
      HIGH   tick
      PAUSE 500
      LOW   tick
        GOSUB Get_Time
        IF mins=$00 AND secs=$20 THEN EXIT
       DEBUG HOME, HEX2 mins, ":", HEX2 secs, CR
       DEBUG CR, CR, "Unauthorized CARD", CR
      LOOP
      DEBUG CLS, CLS                                                             ' Turn OFF Led
      LOW  Invaild_Card
      GOTO main
     '15 Minutes CARD Routine
      Routine1:
      mins=$00
      secs=$00
      GOSUB Set_Time
       GOSUB Get_Time
      DO
      HIGH   tick
      PAUSE 30
      LOW   tick
       IF mins=$00 AND secs=$05 THEN
      HIGH   relay
      HIGH   card15
      ENDIF
        ' Turn ON  Relay
        IF mins=$15 AND secs=$00 THEN EXIT
       GOSUB Get_Time
      DEBUG CR, CR, "15 MIN CARD ", CR
      LOOP
      DEBUG CLS, CLS
      LOW  relay
      LOW  card15        ' Turn OFF  Relay
      GOTO main
     '30 Minutes CARD Routine
      Routine2:
      mins=$00
      secs=$00
      GOSUB Set_Time
       GOSUB Get_Time
      DO
      HIGH   tick
      PAUSE 30
      LOW   tick
      HIGH   relay
      HIGH   card30
      ENDIF
        ' Turn ON  Relay
        IF mins=$30 AND secs=$00 THEN EXIT
       GOSUB Get_Time
      DEBUG CR, CR, "30 MIN CARD "
      LOOP
      DEBUG CLS, CLS
      LOW  relay
      LOW  card30        ' Turn OFF  Relay
      GOTO main
      '60 Minutes CARD Routine
      Routine3:
      mins=$00
      secs=$00
      GOSUB Set_Time
      GOSUB Get_Time
      DO
      HIGH   tick
      PAUSE 30
      LOW   tick
      IF mins=$00 AND secs=$05 THEN                                                 ' Turn ON Relay
      HIGH   relay
      HIGH   card60
       ENDIF
        IF mins=$59 AND secs=$59 THEN EXIT
       GOSUB Get_Time                                                               ' 60 MIN CARD
      DEBUG CR, CR, "60 MIN CARD "
      LOOP
      DEBUG CLS, CLS
      LOW   relay
      LOW   card60        ' Turn OFF  Relay
      GOTO main
    ·Now wanting to learn Spin· Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    edited 2010-05-24 20:41
    Thank you Sam. I am not adept at programming, however, and am not quite sure how to tweak your program so that it meets my needs. What do I do to my code so that, when an RFID card is detected, a seven segment led displays that tag's given number? I am close, but it seems as though my programming is slightly off. Right now, I am trying to get the system to be capable of detecting five rfid tags and consequently displaying their respective numbers on the led display.
    ' Started....
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    TMidi CON 12
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    TMidi CON 60
    T38K4 CON 45
    #CASE BS2PX
    T1200 CON 3313
    T2400 CON 1646
    T4800 CON 813
    T9600 CON 396
    T19K2 CON 188
    TMidi CON 108
    T38K4 CON 84
    #ENDSELECT
    SevenBit CON $2000
    Inverted CON $4000
    Open CON $8000
    Baud CON T2400
    #SELECT $STAMP
    #CASE BS2, BS2E
    #CASE BS2SX
    #CASE BS2P
    #CASE BS2PE
    #CASE BS2PX
    #ENDSELECT
    LastTag CON 5
    #ELSE
    #ENDIF
    pinCounter VAR Nib
    OUTH = %00000000
    DIRH = %11111111
    Reset:
    Main:
    #ELSE
    #ENDIF
    Subroutine_Name:
    Check_List:
    #ELSE
    #ENDIF
    OUTH = %10000100
    PAUSE 1000
    END
    OUTH = %11010011
    PAUSE 1000
    GOSUB Subroutine_Name
    RETURN
    END
    OUTH = %11010110
    PAUSE 1000
    END
    OUTH = %10110100
    PAUSE 1000
    END
    OUTH = %01110110
    PAUSE 1000
    END
    DIRH = %00000000
    ENDIF
    NEXT
    NEXT
    Bad_Tag:
    tagNum = 0
    PAUSE 1000
    GOTO Main
    Tag_Found:
    GOTO Main
    END
    Show_Name:
    LOOKUP tagNum,
    DO
    END
    LOOP
    RETURN
    ·Try something like this
    ' File.......
    ' Purpose...  To use RFID Card Reader and different Routine
    ' Author....  Sam
    ' Started....
    ' To use differnet Card for----->>
    ' EXAMPLES
    '  Routine0:  DEBUG " Card Not Found "
    '  Routine1:  DEBUG "Welcome Raymond"              '1
    '  Routine2:  DEBUG "Go Away Sarafina!"            '2
    '  Routine3:  DEBUG "Nice Hair Josiah!"            '3
    '  Routine4:  DEBUG "Failure is NOT an Option!"    '4
    '  Routine5:  DEBUG "Hunter is the Winner!"        '5
    '   Started....
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
        T1200       CON     813
        T2400       CON     396
        T4800       CON     188
        T9600       CON     84
        T19K2       CON     32
        TMidi       CON     12
        T38K4       CON     6
    #ENDSELECT
    SevenBit        CON     $2000
    Inverted        CON     $4000
    Open            CON     $8000
    Baud            CON     T2400
    #SELECT $STAMP
      #CASE BS2, BS2E
    #ENDSELECT
    LastTag         CON     5
    #ELSE
    #ENDIF
    Tag1            DATA    "04158DD890"                          ' valid tags #
    Tag4            DATA    "0000000000"                          ' your card #
    Name0           DATA    " Card Not Found "
    Name1           DATA    " Welcome Raymond ", CR, 0
    Name2           DATA    " Go Away Sarafina! ",  CR, 0
    Name3           DATA    " Nice Hair Josiah! " , CR, 0
    Name4           DATA    " Failure is NOT an Option!" , CR, 0
    Name5           DATA    " Hunter is the Winner! " , CR, 0
    Reset:
    OUTH = %00000000
    DIRH = %11111111
    Main:
       DEBUG CLS, CLS
      #ELSE
      #ENDIF
    Check_List:
          #ELSE
          #ENDIF
        NEXT
      NEXT
    Bad_Tag:
      tagNum = 0
      GOTO Routine0
    Tag_Found:
    ON tagNum GOSUB Routine0,  Routine1, Routine2, Routine3, Routine4, Routine5
    Show_Name:
      LOOKUP tagNum,
      DO
      LOOP
      RETURN
     Routine0:
      PAUSE 500               ' Your code for  " Card Not Found "
      RETURN
      Routine1:
      OUTH = %10000100       '"Welcome Raymond" '1
      PAUSE 1000
      RETURN
      Routine2:
      OUTH = %11010011      ' "Go Away Sarafina!" '2
      PAUSE 1000
      RETURN
      Routine3:
      OUTH = %11010110     ' "Nice Hair Josiah!" '3
      PAUSE 1000
      RETURN
      Routine4:
      OUTH = %10110100     ' "Failure is NOT an Option!" '4
      PAUSE 1000
      RETURN
      Routine5:
      OUTH = %01110110    ' "Hunter is the Winner!" '5
      PAUSE 1000
      RETURN
    Sam
    Post Edited (sam_sam_sam) : 5/25/2010 12:15:46 AM GMT
