Propellor Robot control board Question
can this microcontroller:
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/584/Default.aspx
be used to drive this rfid reader?
http://www.robotshop.ca/apsx-rw-310-rfid-reader-writer-module-ttl-1.html
Im also looking to power 10 range finders, the rfid reader, and a text to voice module. Can this prop board handle it?
forgive me if these questions are very simple, or if I have not provided enough information. This is my first take at a robot.
I will be using this as my base:
http://www.parallax.com/Store/Robots/AllRobots/tabid/128/CategoryID/3/List/0/SortField/0/Level/a/ProductID/666/Default.aspx#
any help anyone can provide is greatly appreciated.
Post Edited (p00ndawg) : 5/18/2010 6:46:38 PM GMT
Thank you for that. You answered quite a few of my questions, and even some follow up question. I am going to be using PING))) range finders however, so that should be great.
http://www.robotshop.ca/content/ZIP/rfid-direct-talk-application-RW-310.zip This link contains that data sheet for the RFID reader which states these pin conditions:
Pin 1: Ground
Pin 2 & 3: Not Used
Pin 4: 5V (Regulated)
Pin 5: TX (Serial Transmit)
Pin 6: RC (Serial Receive)
Pin 7: Ground
Pin 8: Not Used
I am more than certain the text to voice module will work, because it is actually hooked up to another parallax board at the moment.
Thanks for all the help, if you have any suggestion or comments please feel free to post.
Thanks!
