Color Sensor
I would like to know how to fix the color sensor into the boe-bot. The color sensor is TCS3200 and which cable do i need to use.
Yours Sincerely
James
Yours Sincerely
James
Look here at Parallax products page,·here is·pdf files and codes, you can download.
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/429/Default.aspx?txtSearch=color+sensor
I saw the pdf and is not using Boe-Bot. So i wan to know the detail.
James
At the end, everything will became Electrons...!
- Stephen
So I need to buy BASIC Stamp DB-Expander Daughterboard-to-SIP then i also need the color sensor inside.
James
I would like to know can I able to solder the pin as I went to ask the supplier they do not have the stock, as i need it urgently. So I not sure which pin is for which. E.g S0,S1,S2,S3 n so on.
Yours Sincerely
James
DF11-12DS-2DSA(05)
DF11-12DS-2DSA(06)
DF11-12DS-2C (This is a free-hanging housing that requires crimp inserts.)
Or, if your supplier carries the DB extension cable, you can simply cut the wires off at the male end and connect to those directly.
I hope this helps. Meanwhile, please have your supplier contact Parallax about carrying the full line of MoBo products.
I don't understand the part numbers:
DF11-12DS-2DSA(05)
DF11-12DS-2DSA(06)
Yours Sincerely
James
These are manufacturer's part numbers for Hirose connectors. You will have to find a supplier of Hirose brand connectors in your location in order to obtain one. DigiKey carries them in the U.S. and also, perhaps, where you are located.
I stay in Singapore. I have went down to the supplier to see whether i can do my own cable and i done it just now. I noticed that got 4 wire no need to connect as I refer to DB-Expander Daughterboard-to-SIP (#28325). So now is the programming part i stuck. As my boe bot got IR and gripper. So the color sensor is the modify to make it better. Do you have any programming that can assist me.
