problems with: Wheel Kit with Position Controller/HB25
I have the Motor Mount and Wheel Kit with Position Controller in conjunction with HB25's.
I have checked and double checked the connections. I had this set up working about 9 months ago. changed nothing, now it doesn't work.
I swapped out the Propeller with a Prop studio board. does the same thing. I downloaded the Roll demo from the OBEX and it does the same thing.
Symptoms:
when I run the roll demo, I turn on the prop wait a sec, turn on the motors (via a switch). motors are stationary. the code waits 5 seconds then goes forward for 5 seconds, which the motors do with out issue. once the code has finished, the motor "go crazy" going forward, backwards pulsing like crazy etc. I have to totally reset every thing for them to work.
I changed the code to go forward then backwards, and it completed the forward command and then went crazy.
any help would be appreciated, I've exhausted my options.
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
Symptoms:
DGSwaner
