Handling 32 bit numbers
tdodds
I have a project where I am gathering and reporting data from several ModBus devices using RS485.·I have the·hardware working just fine, but these·devices report some of their values in 32-bit signed-integer or 32-bit floating-point. Is there a subroutine that I can·adopt to convert these values into ASCII strings (hopefully in SX-B)? In my site search I found a routine for 16 bit numbers (BIN16DEC) and that works just fine for the 16bit registers, but offhand I can't·visualize·a way to expand it·to·handle·these large numbers (a one in the 31st position has to report as ASCII 1,073,741,824 !) and it has to also handle the sign bit.
Thanks for the help.
32bit to BCD packed and ASCII 10 digits
and
24bit signed to ASCII 8/9 digit decimal
I can't remember if the former handles the sign, if it doesn't, you should be able to crib the relevant code from the 24 bit routine.
www.sxlist.com/techref/ubicom/lib/math/radix/index_sx.htm
DEVICE sx28,oscxt2, turbo,stackx,optionx,BOR26
FREQ 8_000_000
ArrayByte VAR byte (12)
send VAR byte
TmpB1 VAR Byte
temp VAR Byte
TmpW1 VAR Word
WX VAR Word
WY VAR Word
RM VAR Byte
TX_BYTE SUB 1,2 'transmit byte
Bin32DEC SUB 1,4 ''Create ASCII string from double word
Start:
Bin32DEC 0,0,0,128 'ENTER 32 BIT NUMBER -Param1 (leftmost) is least significant byte
For J = 0 to 9
ArrayByte(J) = ArrayByte(J) + 48
Tx_Byte ArrayByte(J)
Next
Pause 2000
Goto Start
TX_BYTE:
SEROUT Send, N9600, __PARAM1 ' send the byte
return
Bin32DEC:
WX = __WPARAM34 'Most significant word
WY = __WPARAM12 'Least significant word
for I = 9 to 0 Step -1
TmpW1 = WX//10 'high remainder
temp = TmpW1_LSB
WX = WX/10 'high word quotient
TmpW1 = WY//10 'remainder calc
TMPB1 = TmpW1_LSB
RM = temp * 6
RM = RM//10
RM = RM + TmpB1
WY = WY/10 'Low word quotient
TmpW1 = RM/10 'WY = (WY/10)+(RM/10)+(temp*6553)+(Temp*6/10)
WY = TmpW1 + WY
TmpW1 = temp*6553
WY = WY + TmpW1
TmpB1 = Temp*6
TmpB1 = TmpB1/10
WY = WY + TmpB1
RM = RM//10 'final remainder
Arraybyte(I) = RM
next
return
