Composite one pin tv - How to setup?
I have bought a Piranha Extreme PSOne lcd.
I don't think it can be hacked into vga since there is only a yellow ( composite) whire to the mainboard.
Anyway... I'd like to know how to tell in the spin file that i want to use pin 20?
I can't find it anywhere. Any tips on vga hack are welcome!
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
Post Edited (Botdocter) : 5/17/2010 1:13:29 AM GMT
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
I always have someone watching my back.
VGA normally uses 8 pins and they have to be a group, so you cannot use P20-27. So they have to be P0-7, P8-15 or·P16-23.
The pdf is from the original sony lcd. I have the piranha extreme variant.
Wich does Not have vga... Or at least not connected to the mainboard. There are some solderplates though wich say r/g/b. But like i said, not connected
Post Edited (Botdocter) : 5/17/2010 3:41:55 AM GMT
so how can i use this to get the graphical demo working?
i want to show a face( picture,pixels or something else) and a scrolling map that now outputs "." and "#" to the terminal. It works fine but i'd like to have a nice coloured version of the map. without the characters, and instead nice filled blocks/sectors? scrolling image that relates to my coordinates?
To get color, you will need 3 prop pins and 3 resistors. See the Prop ProtoBoard schematic for this (uses P12, 13 & 14). P15 is used for audio so you do not need it. You can reprogram to use P20,21,22.
You will find TV demos in the OBEX. There are text only and color blocks/tiles. I suggest you try them for a start.
Page 4 - The reversable videocard
http://ucontroller.com/Propeller%20Protoboard%20Designs%20for%20the%20Beginner.pdf
So i have a big dark bar on the bottom and above 2.5 inputs with an even amount of space between them ( virtically)
help please!! I'm so close!!
