i want to set a basic stamp program for a switch , it is one switch to one mode, i have four mode,that will has four switch to four different mode.how can i set this program,Can somebody help me,Thank
Keep a counter that your program initializes to zero. Use the BUTTON statement to handle the switch. When the BUTTON statement succeeds, increment the counter. If the counter reaches 4, set it back to zero. The counter value provides the mode
' {$STAMP BS2}
' {$PBASIC 2.5}
DIRA=0
DIRB=15
DIRC=15
DIRD=15
MAINProgram:
loopcounter VAR Byte
FOR loopCounter = 0 TO 99
DEBUG HOME, "loopCounter =", DEC loopCounter
IF IN0=0 THEN· MODE1
IF IN1=0 THEN· MODE2
IF IN2=0 THEN· MODE3
IF IN4=0 THEN· MODE4
PAUSE 1000
NEXT
SLEEP 100
GOTO mainprogram
MODE1:
cmConstant CON 2257
cmDistance VAR Byte
time······ VAR Word
DO · PULSOUT 15, 5 · PULSIN 15, 1,time · cmDistance = cmConstant**time · SEROUT 14, 84, [noparse][[/noparse]22, 12] ' Initialize LCD · PAUSE 5 · SEROUT 14, 84, [noparse][[/noparse]"Distance Mode" ,CR, DEC3 cmDistance,"cm" ] · PAUSE 100 · IF IN1=0 THEN· MODE2 · IF IN2=0 THEN· MODE3 · IF IN4=0 THEN· MODE4
LOOP
MODE2:
angle VAR Byte
x VAR Word
y VAR Word
DO
PULSIN 6, 1, x
PULSIN 7, 1, y
x = (x MIN 1921 MAX 3164) - 1921** 13369 - 126
y = (y MIN 1921 MAX 3164) - 1921 ** 13369 - 126
angle = -x ATN y
angle = angle*/363
IF angle>180 THEN angle=360-angle
IF angle=0 THEN FREQOUT 4,10000,2
PAUSE 5
SEROUT 14, 84, [noparse][[/noparse]"Degree Mode" ,CR, "angle = " ,CLREOL,DEC angle,"deg" ]
PAUSE 100
LOOP
MODE3:
lux VAR Word
h VAR Nib
z VAR Word
cnt VAR Word
y1 VAR Byte
y2 VAR Word
S0 PIN 8 'Sensitivity selection pins
S1 PIN 9
In PIN 10 'TSL230R output pin
DO
Program Start
LOW S0 'Set sensitivity pins (S0,S1) to x10
HIGH S1
Main program loop
h=$0014
y1 = cnt */ h
y2 = y1 * cnt */ h */ h
FOR z = 0 TO 2000
COUNT In, 100, cnt 'COUNT on P2 FOR 100 ms, store value in cnt
lux = cnt*/$39A-36-y2
DEBUG HOME , DEC5 lux,CR 'Display value of cnt as a decima
PAUSE 5
SEROUT 14, 84, [noparse][[/noparse]"Lux Mode" ,CR,"Lux = " ,CLREOL,DEC lux,"lux" ]
NEXT
LOOP
MODE4:
ShtData PIN 11 ' bi-directional data
Clock PIN 13
ShtTemp CON %00011 ' read temperature
ShtHumi CON %00101 ' read humidity
ShtStatW CON %00110 ' status register write
ShtStatR CON %00111 ' status register read
ShtReset CON %11110 ' soft reset
Ack CON 0
NoAck CON 1
No CON 0
Yes CON 1
ioByte VAR Byte ' data from/to SHT11
ackBit VAR Bit ' ack/nak from/to SHT11
toDelay VAR Byte ' timeout delay timer
timeOut VAR Bit ' timeout status
soT VAR Word ' temp counts from SHT11
tC VAR Word ' temp - Celcius
status VAR Byte
'Initialize:
GOSUB SHT_Connection_Reset ' reset device connection
PAUSE 250 ' let DEBUG window open
Main:
DO
PAUSE 5
SEROUT 14, 84, [noparse][[/noparse]"Temp Mode" ,CR,"tC = " ,CLREOL, DEC tC,· "C"]
GOSUB SHT_Measure_Temp
PAUSE 1000
LOOP
SHT_Connection_Reset:
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]$FFF\9]
SHT_Start:
INPUT ShtData ' let pull-up take high
LOW Clock
HIGH Clock
LOW ShtData
LOW Clock
HIGH Clock
INPUT ShtData
LOW Clock
RETURN
SHT_Measure_Temp:
GOSUB SHT_Start ' alert device
ioByte = ShtTemp ' temperature command
GOSUB SHT_Write_Byte ' send command
GOSUB SHT_Wait ' wait for measurement
ackBit = Ack ' another read follows
GOSUB SHT_Read_Byte ' get MSB
soT.HIGHBYTE = ioByte
ackBit = NoAck ' last read
GOSUB SHT_Read_Byte ' get LSB
soT.LOWBYTE = ioByte
tC = soT ** $1999 - 400 ' convert to tenths C
RETURN
SHT_Write_Status:
ioByte = ShtStatW
ioByte = status
RETURN
SHT_Read_Status:
ioByte = ShtStatW ' write to status reg cmd
GOSUB SHT_Read_Byte ' send command
ackBit = NoAck ' only one byte to read
GOSUB SHT_Read_Byte
RETURN
SHT_Write_Byte:
SHIFTOUT ShtData, Clock, MSBFIRST, [noparse][[/noparse]ioByte] ' send byte
SHIFTIN ShtData, Clock, LSBPRE, [noparse][[/noparse]ackBit\1] ' get ack bit
RETURN
SHT_Read_Byte:
SHIFTIN ShtData, Clock, MSBPRE, [noparse][[/noparse]ioByte] ' get byte
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]ackBit\1] ' send ack bit
INPUT ShtData ' release data line
RETURN
SHT_Wait:
INPUT ShtData ' data line is input
timeOut = No ' assume no timeout
FOR toDelay = 1 TO 250 ' wait ~1/4 second
IF (ShtData = 0) THEN EXIT
PAUSE 1
NEXT
IF (toDelay = 250) THEN timeOut = Yes ' loop completed = timeout
RETURN
SHT_Soft_Reset:
GOSUB SHT_Connection_Reset ' reset the connection
ioByte = ShtReset ' reset command
ackBit = NoAck ' only one byte to send
GOSUB SHT_Write_Byte ' send it
PAUSE 11 ' wait at least 11 ms
RETURN
Heater_On:
status = %00000100 ' heater bit = On
GOSUB SHT_Write_Status
RETURN
Heater_Off:
status = %00000000 ' heater bit = Off
RETURN
- Stephen
' {$STAMP BS2}
' {$PBASIC 2.5}
DIRA=0
DIRB=15
DIRC=15
DIRD=15
MAINProgram:
PAUSE 1000
NEXT
SLEEP 100
GOTO mainprogram
MODE1:
cmConstant CON 2257
cmDistance VAR Byte
time······ VAR Word
DO
· PULSOUT 15, 5
· PULSIN 15, 1,time
· PAUSE 5
· PAUSE 100
LOOP
MODE2:
angle VAR Byte
x VAR Word
y VAR Word
DO
PULSIN 6, 1, x
PULSIN 7, 1, y
angle = -x ATN y
angle = angle*/363
PAUSE 5
PAUSE 100
LOOP
MODE3:
lux VAR Word
h VAR Nib
z VAR Word
cnt VAR Word
y1 VAR Byte
y2 VAR Word
S1 PIN 9
DO
Program Start
HIGH S1
Main program loop
h=$0014
y1 = cnt */ h
FOR z = 0 TO 2000
PAUSE 5
NEXT
LOOP
MODE4:
Clock PIN 13
Ack CON 0
NoAck CON 1
No CON 0
Yes CON 1
status VAR Byte
'Initialize:
Main:
DO
PAUSE 5
PAUSE 1000
LOOP
SHT_Start:
LOW Clock
HIGH Clock
LOW ShtData
LOW Clock
HIGH Clock
INPUT ShtData
LOW Clock
RETURN
SHT_Measure_Temp:
RETURN
SHT_Write_Status:
ioByte = ShtStatW
ioByte = status
RETURN
SHT_Read_Status:
GOSUB SHT_Read_Byte
RETURN
SHT_Write_Byte:
RETURN
SHT_Read_Byte:
RETURN
SHT_Wait:
PAUSE 1
NEXT
RETURN
SHT_Soft_Reset:
RETURN
Heater_On:
RETURN
Heater_Off:
RETURN
i only want to press one button display one mode ,i can't do it
if some where in your code you need to select a different mode the just rescan the select mode
Scan_Mode:
NEXT
PAUSE 1000
RETURN
Then any time you need to select a different mode· then use GOSUB Scan_Mode
I hope this help
·Now wanting to learn Spin· Thanks for any·
Sam
