__trisc var not defined going from SX28 to SX48 [solved]
Yendor
I'm moving my project from an SX28 to SX48 for some additional breathing room.
When I compile the code on the SX48, the following error occurs:
··MOV FSR,#__TRISC
Error 3 Pass 2: Symbol <__TRISC> is not defined
I see __TRISX(0) var at $FF, but don't see __TRISC var·like I did on the SX28.
How does __TRISX function in collaboration·with __TRISC and the other __TRIS vars on the SX48?
Thanks!
[noparse][[/noparse]update] not sure if this is correct, but defining __TRISC as a byte var compiles, at least.
Post Edited (Yendor) : 5/17/2010 5:43:35 PM GMT
··MOV FSR,#__TRISC
Thanks!
What line of SX/B code is generating the "MOV FSR,#__TRISC" line ?
The SX48 doesn't use individual __TRISA, __TRISB, etc variables because the SX48 can read and write the TRIS registers. On the SX28 they are write only.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
it's from am in line assembly instruction.
I am still unclear what to do,as of yet.
Any help appreciated!
It's from the serial code interrupt.
Now I have another one, which comes up with another thread.
