Upgrade
I would like to upgrade my boe-bot, can anyone have recommend as for now I doing IR + gripper. Any suggestion.
Yakupt
Yakupt
You could add a wireless control link to a PC using xBee
You could add a PING to supplement the IR. You'd have to figure out another way to mount the PING servo since the gripper is in the way or use a fixed mount for the PING and turn the whole BoeBot the way you have to do now to scan the environment with IR.
You could change over to a Propeller either using a SpinStamp or making your own Propeller Boe using a Protoboard as was done here:
http://forums.parallax.com/showthread.php?p=635533
I would like to do some basic upgrade as I unable to spend a lot of time doing as i also have my part time job. Thanx for the reply and i saw your forum is very interesting but i don't think I able to do that as I new to the robot.
Yakupt
- Stephen
If you want "real music" like MP3 files or WAV files, you'd need to add something like the Vinculum VMusic2 or some other MP3/WAV player chip and an SD card to hold the music.
Can I use the pizospeaker?
Yakupt
