Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Looking for a 12v powered RFID reader — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
p00ndawg
70
2010-05-15 01:15
edited 2010-05-15 17:57
in
Robotics
does anyone know of any?
or of any way to get a 6v rfid reader to run on a 12v battery?
Thanks!
Post Edited (p00ndawg) : 5/15/2010 1:28:43 AM GMT
Franklin
4,747
2010-05-15 02:10
edited 2010-05-15 02:10
http://www.google.com/search?q=12v+rfid+reader&rls=com.microsoft:en-us&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1&rlz=
or use a "voltage divider"
- Stephen
p00ndawg
70
2010-05-15 02:32
edited 2010-05-15 02:32
Thanks.
I tried that however and I couldnt not find what I was looking for.
I have an RFID reader that is powered by 6v, but I wish to use it with a 12v power source.
do you think this would work?
http://www.chopperscycle.com/Cycle-Sounds-Hardwire/BAGGER/Fairing/Radio-Speaker-Accessories-p6941206.html#
Franklin
4,747
2010-05-15 04:25
edited 2010-05-15 04:25
Don't know, not enough info to make a comment.
- Stephen
20,257
2010-05-15 05:16
edited 2010-05-15 05:16
LM317T
"If you build it, they will come."
p00ndawg
70
2010-05-15 17:57
Hey thanks! I saw that lm317t im just not how sure how I would hook up a 6v jack to it?
im trying to use this rfid:
http://apsx.com/rw310.aspx
here is the datasheet:
http://www.robotshop.ca/content/ZIP/rfid-direct-talk-application-RW-310.zip
USing this microcontroller:
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/584/Default.aspx
The rfid reader has these connections:
Pin 1: Ground
Pin 2 & 3: Not Used
Pin 4: 5V (Regulated)
Pin 5: TX (Serial Transmit)
Pin 6: RC (Serial Receive)
Pin 7: Ground
Pin 8: Not Used
could I not just hook the pin5 to the microcontrollers 5v pins?
Battery:
http://www.mouser.com/ProductDetail/Power-Sonic/PS-1270F2/?qs=sGAEpiMZZMtecf8uz0DafoxKK51Cc2%2bNzNHEDGcYax0=
Post Edited (p00ndawg) : 5/15/2010 6:18:00 PM GMT
Sign In
Register
to comment.
- Stephen
- Stephen
Pin 1: Ground
Pin 2 & 3: Not Used
Pin 7: Ground
Pin 8: Not Used
Battery:
