Best Method for "short run" of PCBs — Parallax Forums
TinkersALotTinkersALot Posts: 535
edited 2010-06-02 19:42 in Propeller 1
Assuming I have either gerber files or accurate resolution PCB trace-layouts on acetate films for double sided PCB design. What is the most cost effective way to get a short run of boards made?
Service Bureau (if so, who)
Self service (if so, what "supplies" would I need)
Thanks in advance to all that reply.
  • smbakersmbaker Posts: 164
    edited 2010-05-15 01:03
    I've used two places - APCircuits and BatchPCB. I can highly recommend APCircuits if you want quick turnaround. If memory serves, the boards are sitting at my doorstep 3 days after submitting the gerber. If there's any issues they'll call and get clarification, which is nice. I think I paid about $70 for two eagle-size (4x3.2") boards plus shipping. That's without silkscreen or solder mask.
    BatchPCB is much slower, but has a better price when doing silkscreen & soldermask or when doing small boards. Problem is it takes a long long time since the boards come from china. It's been about 3 weeks and I'm still waiting on my first order (it should take about a month total at the maximum).
    I've tried making my own boards at home, but it's been time consuming and error-prone (probably due to my inexperience) and I find it much either just to have the boards professionally made.
    Scott
  • edited 2010-05-15 01:18
    One of the websites recommend 4pcb.
    http://4pcb.com/
  • BigFootBigFoot Posts: 259
    edited 2010-05-15 01:21
    We use Imagineering, they have always delivered on time, the quality is consistently
    great and they can also provide production quantities if needed.
    Russ
    edited 2010-05-15 03:05
    I've used both APCircuits (www.apcircuits.com) and Advanced Circuits (4pcb.com). I currently use Advanced Circuits. I rarely do maskless protos anymore, and Advanced Circuits' $33 special is hard to beat. Both do quality work. Be sure to consider the shipping charges from Canada (APCircuits) or the U.S. (Advanced Circuits) in your price comparison.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-05-15 03:22
    I also use Advanced Circuits. They are in Colorado, the quality is top notch and they are easy to work with. Plus, new customers get 50% off their first two orders.
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
  • RaymanRayman Posts: 16,311
    edited 2010-05-15 03:59
    I'm interested in this too... One day, I may try buying the ExpressPCB Gerber files and taking them elsewhere to get made at a lower cost. Sounds like 4pcb.com has a lot of votes...
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
    edited 2010-05-15 04:58
    Phil Pilgrim (PhiPi) said...
    What kind of turnaround time do you get from Advanced Circuits? I'd really like to transition to someone who has both a good price on soldermasked boards and offers a reasonably quick turnaround time. I looked into Advanced Circuits once, but got lost in their myriad of slightly-different websites (advanced circuits, 4pcb, 33each, freedfm, etc)
    Scott
    edited 2010-05-15 05:28
    I use the 33each from Advanced Circuits for protos. It takes a week or so. (BTW, don't eat the microwave popcorn they send with each order. It's really awful. I can't even give it away to my UPS driver. It goes right from the shipping pak to the trash.)
  • HarleyHarley Posts: 997
    edited 2010-05-15 17:01
    I too have used Advanced Circuits for quite a few years now. Not the lowest price, but find their quality to be quite high. Their DFM check helps get boards manufactured without problems too. AC's use of direct laser plotting bypasses the photoplot step eliminating errors from that process. I'd tried others but AC has given good service.
    Harley Shanko
  • T ChapT Chap Posts: 4,260
    edited 2010-05-15 17:11
    I have only used Sunstone, 3 days at your door. The reason I haven't looked elsewhere is that I can upload an Eagle .brd file online, no effort on my end. They have a very easy online method to calculate price. I always order a 12" x 14" board that had numerous boards on it, then route it as needed. I think 6 boards at 12 x 14 with mask and silk is around $550US. One cool thing I can do with Sunstone that I just read that Advanced does not allow, is that where I need a slot, I just overlap drills and get a usable slot(must be large enough drill to not break!) If you compare to Advanced, the price is not bad. Advanced 33 deal is 60Sq inches max. The price per Sq inch does increase with Sunstone if ordering less boards, but past 6 each 12x14 boards the prices start getting cheap.
    Sunstone:
    12" x 14" = 168 square inches
    6 boards x 168 = 1008 @ around $550 = $0.545 cent per Sq inch
    Advanced:
    60 Sq inches max @ $33 = $0.55 per Sq inch.
    Post Edited (Todd Chapman) : 5/15/2010 5:25:18 PM GMT
  • max72max72 Posts: 1,155
    edited 2010-05-18 13:06
    I used Olimex, and for an European customer is a nice option.
    Only Eurocard format, but they depanelize for free.
    Massimo
  • Jay KickliterJay Kickliter Posts: 446
    edited 2010-05-18 13:27
    I can second Sunstone Circuits. I forget what I paid for last batch of 4 PCBs, but I believe it was less than $50. They were small, and almost entirely surface mount, but they were definitely cheaper than Advanced, who I used to use. It also seems to me that their website is easier to use.
  • Chad GeorgeChad George Posts: 138
    edited 2010-05-18 13:38
    I use advance circuits (4pcb.com)
    I love the free DFM check service they provide. Of course I do my own checks before I send it off, but I really like having the fabricators system do a check too so I know we are both getting it right.
    And the $33 / board is a great deal
    normally I don't use anywhere near 60 square inches on a single pcb so I always panelize the boards and cut them apart myself.
    Buy 4 boards and get 1 free, but there's a $50 charge for multiple boards per panel
    Here's a recent project:
    9 small pcbs + 2 medium pcbs per panel
    = 55 boards @ $206 delivered price = ~ 2.75 per board.
    If its shipping to a school address ... you can order as few as 1 board at a time.
    Oh and I totally agree with Phil about about AC's popcorn!
  • mparkmpark Posts: 1,336
    edited 2010-05-18 15:55
    edited 2010-05-18 16:32
    Chad George said...
    Could you give any additional information about the procedure to panelize the boards? I'm using Eagle. Is there a particular program that you use to postprocess the gerbers to panelize, or is the panelization built into the layout software you're using?
    Also, what process do you use to cut the boards apart? Any special tools?
    This really sounds like it could be the cost-effective way to go, as I often have lots of small projects I could easily combine into a panel.
    Scott
    edited 2010-05-18 18:00
    The panelization feature is built into my software (altium) but I'd be shocked if Eagle doesn't have some way of doing it too.
    For cutting them apart, I space everything 1/8th inch and use my dremel with metal cutoff blades. After cutting I use a belt sander to trim them down to the right size.
    I've tried to use a scroll saw before, but the pcb material eats up blades like crazy, so the dremel works the best for me until I find a blade that can keep up.
  • DynamoBenDynamoBen Posts: 366
    edited 2010-05-19 02:46
    I use www.pcbfabexpress.com. Quality is very high, they are less expensive that others (price breaks start at 3 boards), and they make all their boards in CA (not sent to China).
  • Nick McClickNick McClick Posts: 1,003
    edited 2010-05-19 05:49
    @Phil - yes, the popcorn is awful, but I am a hungry man... actually, my microwave usually burns a hole through the bag.
    I appreciate the thought, though, so I usually put a 'token of appreciation' with orders I ship.
    Propeller Forums RSS Feed!
    Gadget Gangster - Share your Electronic Projects
    edited 2010-05-19 07:39
    The best thing Advanced Circuits ever sent out with their orders was a pad of sticky notes with their logo and phone number. It was not only good advertising for them but very handy to have around. The order I got from them yesterday just had the d**n popcorn -- no sticky notes. Into the trash it went. I've also had suppliers send hard candy with their orders. Another instant wastebasket item. Then there's Parallax. They sent a catalog, which is nice all by itself. But inside the catalog is a calendar. What's great about the calendar, in addition to the cool pictures, is its long, skinny format. I've got mine hanging in a narrow space where no other calendar would fit. I like getting calendars. Another supplier, Universe Kogaku, sends out a really nice one every year with impressionist paintings. Pens are nice, too, but I don't seem to get many of those anymore. Then there's the reusable packing material. Parallax's is the best: inflated polyethylene pillows. They get a lot of those back when I ship stuff to them. Thankfully, not many suppliers still use plastic peanuts. I've got a 32 gallon wastebasket full of recycled ones that I can still foist off on a customer in a pinch.
    Am I starting to sound like Andy Rooney yet? "And what is it with those non-reusable Priority Mail boxes? ..."
  • DogPDogP Posts: 168
    edited 2010-05-19 07:57
    I've used Silver Circuits (www.custompcb.com/) and was happy with it. I mostly went with them because the price was cheap since they didn't force you to use all the extras (I got my PCBs with no soldermask or silkscreening), but still allowed choices, like different thickness PCB. I haven't done any PCBs with them recently, so I don't know if their policies are still the same though.
    Pat
    edited 2010-05-19 11:13
    Phil, what is it with these PCB businesses and gifts? I got the popcorn and a pretty cool coaster from Advanced, but Sunstone sent me a very usable fold out loupe. Sunstone won my future business, mainly because of the loupe. That is, until Advanced sends me a video microscope, then I'll go back to using them.
  • LeonLeon Posts: 7,620
    edited 2010-05-19 12:04
    I've been using PCB Pool for years. Whenever I say hello to them at a show they always give me a little box of chocolates. I've also had a couple of DVMs from them; the displays aren't very reliable - poor contacts - but they can be persuaded to work with a bit of pressure.
    Leon Heller
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 5/19/2010 12:11:42 PM GMT
    edited 2010-05-19 13:40
    Thanks again to all of you that replied and provided a great list of vendors to consider and compare.
    edited 2010-05-19 15:01
    Jay,
    I never got a coaster; now I feel cheated! So I may give Sunstone a try just for the loupe ... er, I mean, for their boards' technical superiority ... yeah, that's the ticket!
    One of my gripes about the popcorn is its not-insubstantial weight -- more than the boards, usually. If I'm in a hurry and have my order shipped overnight, the popcorn makes for a rather expensive "free" gift.
    edited 2010-05-19 16:11
    Phil, Your oft expressed distaste for microwave popcorn is not universal-- I've been saving up my 4PCB packs for the freebie table at UPEW!
    Tracy Allen
    www.emesystems.com
    edited 2010-05-19 17:03
    Tracy,
    Be careful! You could be charged with spreading toxic waste! (I know California is really strict about such things.)
    edited 2010-05-19 17:45
    Ahhh! I should have known. Is PC "politically correct" or "pop corn"? It's not the corn, is it the palm oil plus less than 2% butter (on the way to becoming rancid, but with citric acid for freshness, best by Feb.2011) that "makes movie time special"?
    Back on topic, the thing about PCB houses is that you get used to the way that they do business, how their ordering system works, who to call if you have a problem or special request or need to reorder an old board. There is a certain inertia about change. 4PCB has had a nice online quote system for a long time.
    One thing to remember if you are doing a short run (like 10 to 100 boards) is that you can game the quote system. This may apply to any supplier, not just 4PCB. Once you have decided on the board size and specifics, increase or decreased your quantity requested by small increments. Because boards are manufactured as panels, you may find that changing your quantity by a certain small number hardly increases the total price, but at one more than that sweet spot, it jumps quite a bit.
    Tracy Allen
    www.emesystems.com
    edited 2010-05-19 18:39
    Two pages, now, and not one single mention of a Propeller, not one!
    Why is it in the Propeller Forum?
    edited 2010-05-19 18:42
    Tracy,
    That's good advice. With Advanced Circuits I've found that, up to a certain threshold, you're going to spend about $500 to $700 for a production board order, no matter what the quantity is.
    edited 2010-05-19 18:45
    PJ,
    That's a valid question, but it's certainly closer to Propeller matters than marathon running. smile.gif
