2X16 LCD for $3.99, free postage!
Hello Forum,
I have purchased two of these LCDs, get the chance here·at ebay·a 2X16 LCD for only $3.99 with free postage!
(HD44780 Compatible)
Two colors:
Two colors:
www.smarthome.viviti.com/propeller
Nice enough colors.
I prefer the dark background/green txt ones but these are OK.
after I get them. Got some of both colors.
3.89 shipped
cgi.ebay.com/HD44780-1602-16x2-LCM-Character-LCD-Display-Module-New-/220598325240?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335caf4ff8
3.48 shipped
cgi.ebay.com/NEW-Character-LCD-Module-Display-LCM-1602-16X2-162-blue-/220604499525?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d0d8645
He says if you want several to just make him an offer.
“How much of human life is lost in waiting.” Ralph Waldo Emerson"
Serial ones just cost too much.
You can use a cheap AVR to control this type.
Just epoxy it dead bug style on the back of the lcd board
and wire it up point to point. You could then send it
data with a single prop pin. Cover it all up with a liberal
dose of hot glue. Cover the AVR and wiring with something
like black epoxy and make it look good and you could sell
the things for a profit right here on the board...just put
a lot of useful routines in the AVR code, make it super simple
to use.
When I engineer something like this I always use a dip AVR
and bend the pins flat and snip the pins very short, then epoxy
it down and do the wiring...the internal adjustable timer is adequate
for many uses. I customized a lot of cheap parts to make them easy to use
at my last job..saved many dollars.
3.48 + 1.50 for the AVR and you have a cheap and custom lcd controlled by one pin.
My favorites are the tiny85 and 84 and the Atmega644, 168
and 328.
You need a cheap AVR with enough I/O pins for the lcd display.
That makes the 8 pin tiny chips a no go but a larger tiny with
more pins is perfect. If you use 4 bit mode on the lcd you need
fewer I/O pins. A tiny84 should work. Less than 2 dollars and
has a whopping 8k of flash so you could code a bunch of nice
routines....you could make it really special.
If you modded one of these cheap lcd displays you would have
a nice display for five dollars that could be controlled even from
an 8 pin AVR tiny chip
I wonder if people would buy such a thing for ten dollars?
If so you would double your money with just a small bit
of assembly work.
around 2.5 dollars. The guy said to make an offer on large quantities.
Then buy 100 tiny chips at mouser and you would be looking
at a hardware cost per modified display of slightly less than 4.00
Sell them for 9.99 each and you would make money.
If it catches on though the China sellers would create the
same thing and sell it cheaper....but you would have the market for a while.
Same basic and simple idea.
But mounting a tiny AVR dead bug style on back of the lcd
and selling a wired unit is a better idea I think.
@Martin_H
That would just complicate a simple idea.
The price difference between an 8pin AVR and a larger one is
smaller than the cost of adding the extra chip you see.
Post Edited (HollyMinkowski) : 5/15/2010 7:57:00 PM GMT
http://wulfden.org/TheShoppe/k107/k107.shtml
You can get just the pcb, a pcb with pre programed Pic chip or a complete kit. It is based on the same kit that electrosys·is talking about but more refined.· I use these alot on LCDs I get Off ebay.
Hope this info helps.
· Scott
You are right, if you need lots of (serial) LCDs for same product, that will make a big difference in the prices, but if we taking about a few LCDs for hobby projects, then it's only a few bucks to save, and do not forget the difficulty of the Assembly and AVR works.
One more:·
SpakFun has a Serial enabled LCD·backpack,·the source·code·(C and HEX for PIC16F688/684) Datasheet, Pin assignment and Schematic, are·free to download·for personal use.
http://www.mouser.com/ProductDetail/Newhaven-Display/NHD-0220D3Z-FL-GBW/?qs=sGAEpiMZZMtqO%2bWUGLBzeC3eNvCBKpVr
Yes, it would also be possible to interface a parallel display to a picaxe. I do it all the time. But for ease of use, i would just buy a serial one....
