BS2 I2C BlinkM read data from slave problem (protocol?)
I have purchased a fancy BlinkM thingm.com/products/blinkm (it is a small RGB LED with integrated controller, AVR) and now I'm trying it out. It's connected to my BoeBOT with BS2, so I need software I2C. So far so good!
It's working fine when I send info to the BlinkM but I'm having problems reading data from the little nifty device.
After reading http://forums.parallax.com/showthread.php?p=466264 it is still not clear to me.
To read data from the slave (BlinkM) first I have to send the slave address than send "a" (which is the BlinkM command for Get BlinkM address, default is 0x09) than to receive 1 data byte.
I assume that the exact protocol is my problem, please see the BlinkMCmd_read procedure below, I always receive a 0 instead of 9?
Can anyone point me in the right direction?
BoeBOT with BS2 and PINK module (Netburner) | Latest: BlinkM
' {$STAMP BS2} ' {$PBASIC 2.5} ' {$PORT COM1} ' '---- I/O definitions --------- 'What pins BlinkM is connected to, with 4.7k (or 10k) pullup resistors to +5V (=Vdd) SDA CON 0 ' I2C Data line (d) on P0 SCL CON 1 ' I2C Clock line (c) on P1 SDA_DIR VAR DIR0 ' must match SDA above, 0 is IN, 1 is OUT '---- constants ---------- BlinkM_addr CON 9 ' or set to zero to address all BlinkMs on your I2C bus ' standard I2C address of BlinkM = 0x09 ' BlinkM listens to general call at address = 0x00 Ack CON 0 ' acknowledge = 0 Nack CON 1 ' no acknowledge = 1 '---- variables ---------- I2C_ack VAR Bit ' used by I2CSend, acknowledge from the I2C bus I2C_data VAR Byte ' used by I2CSend, Data to/from the I2C bus slave_addr_read VAR Byte ' slave device address for reading slave_addr_write VAR Byte ' slave device address for writing BlinkM_cmd VAR Byte ' used by BlinkMSend & BlinkMSend3 '---- program ---------- Main: slave_addr_write = BlinkM_addr << 1 ' shift left because address is upper 7 bits, ' direction (READ = 1 OR WRITE = 0) is LSB slave_addr_read = slave_addr_write | %00000001 BlinkM_cmd = "o" ' stop playing boot script, e.g. "{'o'}" GOSUB BlinkMCmd GOSUB BlinkMCmd_read DEBUG "BlinkM address: ", DEC I2C_data, CR END '^^^^^^^^^^^^^^ BLINKM SUBROUTINES ^^^^^^^^^^^^^^ BlinkMCmd: GOSUB I2C_Start ' start procedure I2C_data = slave_addr_write ' check for clock_hold GOSUB I2C_TX_byte ' put address on I2C bus I2C_data = BlinkM_cmd ' check for clock_hold GOSUB I2C_TX_byte ' send command to device GOSUB I2C_Stop ' stop procedure RETURN BlinkMCmd_read: GOSUB I2C_Start ' start procedure I2C_data = slave_addr_write GOSUB I2C_TX_byte ' send address BlinkM_cmd = "a" ' BlinkM command for reading BlinkM address I2C_data = BlinkM_cmd GOSUB I2C_TX_byte ' send command GOSUB I2C_Start ' repeated start procedure I2C_data = slave_addr_read GOSUB I2C_TX_byte ' put address on I2C bus DEBUG "read-address.", CR GOSUB I2C_RX_byte_Nack ' read byte from device GOSUB I2C_Stop ' stop procedure RETURN '^^^^^^^^^^^^^^ BLINKM SUBROUTINES ^^^^^^^^^^^^^^ '---- I2C low level subroutines ---------- I2C_start: ' I2C start procedure SDA_DIR = %1 ' make SDA an output HIGH SDA HIGH SCL LOW SDA RETURN I2C_stop: ' I2C stop procedure LOW SDA HIGH SCL HIGH SDA RETURN I2C_TX_byte: ' transmit 1 byte to device SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]I2C_data\8] ' data = 8 bits long SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]I2C_ack\1] ' get acknowledge bit, MSBFIRST, pre-mode IF I2C_ack =0 THEN DEBUG "Ack - write", CR IF I2C_ack =1 THEN DEBUG "No Ack - write", CR RETURN I2C_RX_byte_Nack: I2C_ack=Nack GOTO I2C_RX I2C_RX_byte: I2C_ack = Ack I2C_RX: SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]I2C_data\8] ' receiving 8 bits of data from device SHIFTOUT SDA, SCL, LSBFIRST, [noparse][[/noparse]I2C_ack\1] ' send acknowledge (Ack or No-ack) to device RETURN
·· Can you get it to respond with the 0x00 (broadcast) address?
Respectfully,
Joshua Donelson
www.parallax.com
I have tried it out with some of the pre-defined light scripts of the BlinkM.
As long as I send data (I2C) al works like it should.
