How the Ping sensor works
I'm using the Ping sensor in a school project. It's important for me to be able to explain (at some level) how the Ping works so that when I give my presentation I can answer any questions that might be asked. I have read the information available on the Ping's webpage and I know that there is an MCU on-board the Ping. I'm guessing that an ADC in the MCU converts the analog signal from the receiver (after it receives the echo), to the digital pulse that gets transmitted from the Ping to the MCU off-board. Is this correct? Can anyone share some other details of the Ping's operation?
Thanks.
Thanks.
The transducers have a pretty sharp mechanical filtering action, so no fancy input filtering is needed (for the ultrasonic pulse). There would be an amplifier and the SX microcontroller which generates the low level transmit pulse and does the timing. There's no ADC used (and none in the SX). The SX's input stage voltage threshold acts as a voltage comparator, so the SX will see several pulses representing the several cycles of ultrasonic energy received by the transducer.
Some·notes here:
I hope this helps.
Parallax Engineering
Post Edited (Chris Savage (Parallax)) : 5/13/2010 8:47:31 PM GMT
