Some advice on how to get the Debug run several objects at a time.
Hello everyone, i'm doing some sort of game on the basic stamp debug terminal, i've managed to connect a NES controller by using the pinout Datasheet. I think I've done all the subroutines working by now, but there's an issue when i try to get the debug terminal running several objects at a time. I leave the code, tnx in advance for the help.
What i want to do is the following; the little "airplanes" should be moving on the x axis only, while someone manages to hit them with the gun at the middle.
You would get a faster answer if you could add english translation comments to your code.
Since many board members use thier spare time.· It takes much effort/time to (1)solve your issue & (2)translate your code..It's like a double whammy.
I myself had to put this aside for now because to look at it now would exceed the time I have alotted to this board.
Before you criticize someone, walk a mile in his shoes. That way if he gets angry, he'll be a mile away and barefoot. - unknown
Post Edited (sumdawgy) : 5/12/2010 1:35:03 PM GMT
