HB25 and Position Controller RX transmission
Hello,
I am using the Motor Mount and Wheel Kit with Position Controllers and 2 HB-25 motor controllers. The connection seems to be right because I can send information to the wheels, and they travel any position, but when I want the current position from the encoders, I don't get any data at all.
The odd part is that I can send information to the encoders, but I dont get anything back. The code I am testing is straight forward from the code given from parallax.
The program gets stuck in the "DisplayPosition" subroutine in "SERIN".
Thanks for your help!
Pedro
Pedro
' {$STAMP BS2pe}
' {$PBASIC 2.5}
'--- Command Value Constants ---
QPOS CON $08 'Query Position
QSPD CON $10 'Query Speed
CHFA CON $18 'Check for Arrival
TRVL CON $20 'Travel Number of Positions
CLRP CON $28 'Clear Position
SREV CON $30 'Set Orientation as Reversed
STXD CON $38 'Set TX Delay
SMAX CON $40 'Set Speed Maximum
SSRR CON $48 'Set Speed Ramp Rate
'--- User Constants & Variables ---
AllWheels CON 0
RightWheel CON 1 'ID of the right side Position Controller
LeftWheel CON 2 'ID of the left side Position Controller
CommPin PIN 2 'communication bus pin
BaudValue CON 32 'for 19.2kbps
Wheel VAR Byte 'Specifies which wheel to command for subroutines
Distance VAR Word 'Used to set the travel distance
RxData VAR Word 'Used to receive data
'--- Initialization ---
PAUSE 1000
SEROUT CommPin, BaudValue, [noparse][[/noparse]SREV + RightWheel] 'Reverses the sensor on the right
SEROUT CommPin, BaudValue, [noparse][[/noparse]CLRP] 'Clears any prior position info
'Go forward 350 positions
Wheel = AllWheels
Distance = 200
GOSUB GoDistance
'Continually check the position of each wheel
CheckLoop:
Wheel = LeftWheel 'LeftWheel
DEBUG "L= "
GOSUB DisplayPosition
Wheel = RightWheel
DEBUG " R= "
DEBUG CR
GOTO CheckLoop
END
'--- Subroutines ---
GoDistance:
SEROUT CommPin, BaudValue, [noparse][[/noparse]TRVL + Wheel]
SEROUT CommPin, BaudValue, [noparse][[/noparse]Distance.HIGHBYTE, Distance.LOWBYTE]
RETURN
DisplayPosition:
SEROUT CommPin, BaudValue, [noparse][[/noparse]QPOS + Wheel]
SERIN CommPin, BaudValue, [noparse][[/noparse]RxData.HIGHBYTE, RxData.LOWBYTE]
RETURN
Do you happen to have an oscilloscope that you can watch the TX to verify that the signal is being sent from the position controller to the BASIC Stamp 2pe? Have you tried another IO pin to see if the issue is IO pin related?
Respectfully,
Joshua Donelson
www.parallax.com
