Noob question
This is my first post to this forum so please go easy. Before you ask, I did spend about 10 minutes searching the forum and couldn't find anything.
I am putting a program together that requires the use of two of the same objects and I just want to make sure it is possible.
1)The object I am referring to is the MMBE object from the exchange.
2)The second object is the FullSerielDuplex.spin. This is used for the MMBE spin as well as the Xbee object.
I just want to know if I can run these without a problem of them stepping all over each other.
In the OBJ section I have:
in the pub section I have
So again, to try to be as clear as I can, the MMBE object uses the FullSerielDuplex.spin object. XBee_Object also uses this object. Is this ok?
XB : "XBee_Object" MMBE1 : "MMBE" MMBE2 : "MMBE"
MMBE1.start(18,19,2400) 'start(txPin, rxPin, baud) MMBE2.start(20,21,2400) 'start(txPin, rxPin, baud)
