2 x16 Parallel LCD (#603-00006) Not Dispalying anything!
Hello,
I've just purchased the 2 x16 Parallel LCD (#603-00006) and when I interfaced the lcd in 4-bit mode with my microcontroller, i could only be able to adjust contrast of the first row of the LCD. Both the first row and second aren't dislaying any characters in 4-bit mode. In 8 bit mode, characters are displayed, but not in English. Could you please explain what could be wrong. I'm using this LCD with a PIC16f887 MCU and using mikroC Pro compiler. As far as the connections are concerned, I've used the exact same connection described in the LCD's datasheet/manual. Unfortunately, not even the Ribbon cable's footprint was provided in the datasheet.
When contrast is only adjustable for one row, what could be the problem? and why isn't it displaying anything in 4 bit mode even when connection to microcontroller is exactly as described in datasheet?
Please help. Didn't know where to discuss this as there is no sub-forums for LCDs?
Thanks.
Thanks.
Have you studied the programs in the Parallax doc's? True, you are using a pic, but I would think it should be easy to port over. The footprint of the cable is provided on page 2.
Shawn Lowe
When all else fails.....procrastinate!
Shawn Lowe
Thanks for replying. I did use the footprint indicated on page 2. And to answer your question, i believe that the lcd is hd44780 compliant, and mikroC pro has a LCD library that initializes all hd44780 lcds successfully. What i want to try is to use another compiler, like the proton+ as shown in the youtube video. But i've never used BASIC in my life before, as i just program using C.
Regarding the LCD's behavior, do you suspect such a scenario could arise when the lcd is not properly initialized ? or due to connection problems (which i highly doubt)?
I also have no idea what the jumpers on the back-side of the lcd mean. I've done the 4-bit connection direct from the connector and i'm assuming thats how it should be done.
Post Edited (underworldman) : 5/11/2010 9:53:16 AM GMT
Shawn Lowe
It worked in 8 bit mode. Between traces of the PCB, there was some minute quantities of solder which i successfully pumped out. And a guy by the name of Mince on the mikroC forum helped me get the library for interfacing in 8 bit mode.
So..
As a note our Parallel LCD is only guaranteed to operate in the overworld.
Parallax Engineering
