I want to write a program that causes my Blackberry to ring when a signal is sent from the Easy Bluetooth Module... Any Ideas how I can get that done?!
First you need to find out what your Blackberry needs from the bluetooth signal to cause it to ring. After you find that out we might be able to help you send that from a stamp or propeller.
- Stephen
