Look at the Propellor. Check the object exchange for some DMX objects. (obex.parallax.com) The Prop can handle DMX directly with the addition of one buffer IC.
I haven't used DMX out of the Prop yet, but I believe that it can.· I have used DMX in to the prop for a more in depth relay controller controlled by DMX.· It used one channel of DMX to basically give a BCD code out on 4 relays.
I used to use the Stamp for several projects, but since learning the Prop, I havn't gone back. I still have a few, but basically the Prop is much cheaper, and does 100x more things then the stamp can.
Jim
This is used along with the Propeller Platform -
www.gadgetgangster.com/find-a-project/56.html?projectnum=201
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
