Switch Mode Power Supply for Propeller Project
Coley
I'm looking for a bit of advice on switch mode power supplies which I know very little about.
I have a design that needs to run off a source voltage of 13.6V DC and the drop from this to 5V and 3V3 means quite a bit of heat will be dissipated so I am looking for something much more efficient that an linear regulator.
My idea is to use the switchmode psu to take the voltage down to 5V and then use an LDO to drop it further to 3V3.
I'll need up to 300mA at 3V3 and I can do thru hole or smt.
Any help will be gratefully received.
Coley
PropGFX - The home of the Hybrid Development System and PropGFX Lite
Coley
Kevin
Post Edited (khd00) : 5/9/2010 2:15:32 PM GMT
Coley
I have used these before.
This one has a 5v and an adjustable output, but costs 14.97
www.ereshop.com/index.php?main_page=product_info&cPath=75&products_id=189
This one is a 5v switcher for just 3.78. I would use this one with a 3.3 low drop out linear...not much heat going from 5 to 3.3 even with a linear.
I think this is just what you need, buy several, you will use them.
Shop around, there is a lot of great stuff at ere and you will find other stuff you can use.
www.ereshop.com/index.php?main_page=product_info&cPath=75&products_id=188
Both can take up to 40v in and source 1 amp without a heatsink.
Coley
Can't even buy the parts for that price! Gold!
"Are you suggesting coconuts migrate?"
Low parts count, it works rather well.
www.national.com/mpf/LM/LM2594.html#Overview
Massimo
