I2C question
G'day guys,
If I want to use one of the I2C lines as an output, is it safe to toggle the SCL line with reckless abandon provided I keep the SDA line pulled high?
"Are you suggesting coconuts migrate?"
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
So a typical application might be clock and data to shift-registers with a separate I/O pin to load the registers. Even the SD card's clock and data in can be the I2C lines and then all you need are 2 other I/O.
Anyway, what's the application?
*Peter*
