Does Sigma-Delta ADC always require its own cog?
I have found several Sigma-Delta objects. But it seems each one requires its own cog. I just need a real simple way to read an analog voltage from an accelerometer. I just need to grab a reading about once a second or so, do not need continuous reading. Range is about 1v to 3v. I am out of cogs. Any ideas?
Thank you.
-Larry
Thank you.
-Larry
If anyone has the object SigmaDeltaADC(SPIN) I would appreciate a copy.
Thanks.
-Larry
The files are available from the ftp site at the lower right side of this page:
·http://www.parallax.com/Store/Books/Propeller/tabid/171/CategoryID/45/List/0/SortField/0/Level/a/ProductID/637/Default.aspx
I also attached the file.
Jim
Dat mADCIdx long 0 ' Gemultiplexter ADC: von ADCInPin bis ADCPutPin-1 mADC_MuxO ' Number of counts to have zero result for grnd voltage on analog input mADC_MuxO0 long 537 ' Offset first input mADC_MuxO1 long 514 ' Offset second input mADC_MuxO2 long 569 ' Offset third input mADC_MuxO3 long 541 ' Offset forth input mADC_MuxV mADC_MuxV0 long 0 ' counts first input mADC_MuxV1 long 0 ' counts second input mADC_MuxV2 long 0 ' counts third input mADC_MuxV3 long 0 ' counts forth input mADC_Val mADC_Val0 long 0 ' normalized input value mADC_Val1 long 0 ' mADC_Val2 long 0 ' mADC_Val3 long 0 ' ADC_Offs long ADC_def_Offs ' ADC offset ADC_Valu long 0 ' ADC counts ADC_Norm long 0 ' ADC value, normalized ADCRunTim long 0 ' Runtime of last convertion con mADCOutPin = 26 ' Multiplexed ADC: compensation pulses mADCInPin = 22 ' Pin 22 up to ADCOutPin: analog inputs mADC_Nmbr = 4 ' Number of channels to scan ADCOutPin = 16 ' single measurement: compensation pulses ADCInPin = 17 ' single measurement: analog inputs ScalF_ADC = 1000 ' Scaling factor ADC PUB Main ' Enable muxed ADC DIRA[noparse][[/noparse]mADCOutPin]~~ ' Pin to output compensation pulses CTRA := %01001_000 << 23 + mADCOutPin << 9 + mADCInPin + mADCIdx FRQA := 1 ' mode: ADC ' Enable single ADC DIRA[noparse][[/noparse]ADCOutPin]~~ ' Pin to output compensation pulses CTRB := %01001_000 << 23 + ADCOutPin << 9 + ADCInPin FRQB := 1 ' mode: ADC ADCRunTim := cnt ' First convertion ADC_Valu := phsb repeat MuxADC PRI MuxADC 'Multiplexed ADC and "normal" ADC { ADC is scanned 20 ms. Value from 0 - 4095 full scale This ADC measures non time critical voltages 'MUX-AD-Converter: feedback Control Output mADCOutPin, Inputs: starting from mADCInPin These ADC's are handled in the main routine in poll-mode MuxADC is called, checks for elapsed time and reads next channel. The output value is counts/time, normalized to 12 bits ADCOutPin Output compensation pulses ADCInPin Input, actively controlling output ADC_Nmbr Number of multiplexed channels ADCIdx actual index from 0 to ADC_Nmbr-1 ADCMuxO offset, the value determined at input voltage 0 (gnd) } if cnt - ADCRunTim > clkfreq/500 ' measure if more than 2 ms elapsed ( if longer time: take care of shift operation: overflow!) ADC_Valu := phsb - ADC_Valu mADC_MuxV[noparse][[/noparse]mADCIdx] := phsa - mADC_MuxV[noparse][[/noparse]mADCIdx] ' number of counts during last sequence ADCRunTim := cnt - ADCRunTim ' time elapsed ADC_Morm := ((ADC_Valu<<12 / ADCRunTim - ADC_Offs) * ScaF_ADC) ~>12 ' shift: possible overflow! mADC_Val[noparse][[/noparse]mADCIdx] := ((mADC_MuxV[noparse][[/noparse]mADCIdx]<<12 / ADCRunTim ) - mADC_MuxO[noparse][[/noparse]mADCIdx]) <<12 / (4096- mADC_MuxO[noparse][[/noparse]mADCIdx]) mADCIdx := (mADCIdx+1) // ADC_Nmbr ' next index CTRA := %01001_000 << 23 + mADCOutPin << 9 + mADCInPin+mADCIdx ' Activate new control input ' optional: wait 100 µs to increase precision mADC_Valu := phsb mADC_MuxV[noparse][[/noparse]mADCIdx] := phsa ADCRunTim := cntAs the integration time influences the result, the tick count has to be normalized to the elapsed time. At full scale, the ticks are equal to clock cycles and therefor, to have a result >1 , the ticks have to be shifted. Also take into account, that 0V doesn't give zero counts.
It is also shown, how to measure more inputs with a single counter. Just connect the compensation output to different compensation networks and dynamically switch the compensation input of the counter. It works quite well, determine the offset by grounding the input. The result is not depending on the actual cycle time, therefor the routine can be called more or less periodically, if only you take care of the overflow. As full input gives an overflow after 50 seconds, measuring less than 100 hz will create an overflow if the shift value is 12 bits.-
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
-Larry
