Interfacing loadcell with 3mV output to ARM controller
what amplifier and ADC shall I use for interfacing loadcell with 3mV output to ARM controller
Post Edited By Moderator (Joshua Donelson (Parallax)) : 5/14/2010 12:13:43 AM GMT
- Stephen
First, you need to replace the ARM with a Prop.
Then, we need more info on the load cell (as Stephen indicated). Is the load cell already amplified? Does it have a built in Wheatstone Bridge?
Normally, you don't just connect the load cell to a ADC, but there is some external cricuitry (either outside the load cell, or built into it).
John R.
Click here to see my Nomad Build Log
