Survey - XBee USB Adapter Offering
Bump
Survey - XBee USB Adapter·- http://www.parallax.com/XBeeUSBSurvey/tabid/864/Default.aspx
We would like your input on how we offer the XBee USB Adapter. This simple survey will be used to gauge your header-pin configuration preference. Your input will help us provide exactly the product you want.
At present, our XBee USB Adapter includes (2) 0.1" male/male headers and (2) 2mm male/female headers that are not installed by Parallax Inc. They are put in a bag with the product and the customer decides whether or not to install them.
Survey available:
Survey available:
To our friends: we need your input on this particular issue. Not only for this product, but these questions often apply to other products we manufacture (i.e., other XBee adapters).
If YOU tell us what YOU WANT, we will do it!
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Or at least identify the pin desctiption by pin number in the literature. Sure would help.
I went back and looked at the documentation and I can see what you mean. The schematic does not show the pin numbers next to each pin descriptor. I will revise the documentation to add a diagram next to the module dimensions that makes the pin assignments more clear from a top-down perspective.
Parallax Engineering
Also, having read some of the Forum posts it seems some users are having difficulty connecting these boards to their Stamps. Another suggestion would be for you to add some graphics showing those connections - as a minimum... those similar to what you show for connecting the Memsic 2125 Dual-axis Accelerometer. (It takes a while to sort through all of the references to the DOUT's, the DIN's, and the I/O's.)
We all end up getting it in the end, but I find that its not on par with Parallax's very, very user friendly standards for presenting documentation.
Post Edited (Wildatheart) : 5/7/2010 3:57:08 PM GMT
As for the numerical references to pins 31 through 34, I was unable to locate those references in the documentation. Could you please clarify for me where these exist?
Actually, it'd good to leave the revised schematic in the docs, but for a quick and clean setup it might be clearer if you simply displayed the adapter board pins without the adapter board components and their connection to the Xbee - again, similar to what you did for the Mesmic docs.
Post Edited (Wildatheart) : 5/7/2010 5:12:13 PM GMT
Best Regards,
You didn't comment on my second suggestion.
Survey is tied at 2 options! This may make it harder for Parallax to decide!
Jim
I'm turning 40 in January I've got to admit that reading the PCB notation is a challenge.
(Granted I had my vision set for distance when I had cataracts removed...but...) [noparse]:)[/noparse]
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
Best Regards,
