Help with X4/X5 outputs on the boe board
Hi, my problem is that I am using a motor on the boe board connected through the X4 and X5 outputs so that it can get more power.
The problem is that power is always being supplied to the x4/x5 outputs and it is controlled by turning on and off a signal which is the third wire on the servo motors, however our motor only has two inputs.· Therefore the power is always being supplied to the motor and we cannot turn on/off the power does anyone have any tips on how to program it so that i can control when the power is being supplied.
Thanks for the help
Thanks for the help
You can set up the transistor on the BOE's breadboard area or you can even wire a switching transistor into your cable to your motor if you have the 3rd wire from x4/x5 available already in the cable.
