FSRW26 C version — Parallax Forums
FSRW26 C version
RsadeikaRsadeika Posts: 3,846
edited 2010-05-07 20:59 in Propeller 1
I just downloaded FSRW26.zip, and to my surprise I found a C source file listing in the zip file. The first thing, I tried to compile it with ICC, which did not compile, it came up with some errors that mentions something about C++. Does anybody know anything more about this, like which compiler you need to use to make this thing work? Was there a discussion about this that I completely missed? Or, is this an evil plot by the authors to make you think that you can use C LOL.
Ray
  • heaterheater Posts: 3,370
    edited 2010-05-06 12:59
    What errors exactly ?
    For example C++ allows comments with // maybe ICC does not.
  • hairymnstrhairymnstr Posts: 107
    edited 2010-05-06 13:13
    Somewhere in the FSRW2.6 package it explains that they write the code in C and test it then translate to SPIN using the C to SPIN Perl script that's in the folder. So the C is not intended to be run directly on the Prop.
    Nathan
    "Free as in freedom, beer gratefully accepted though."
  • RsadeikaRsadeika Posts: 3,846
    In the program listing it contains:
    #include <cstdio>
    #include <cstdlib>
    #include <cstring>
    The error(s) are basically "... (The header cstdio requires C++)". As I was glancing at the listing, I did not notice the "cstdio, cstdlib, cstring" #include statements. Maybe I missed those three files somewhere in the zip file.
    Ray
    edited 2010-05-06 13:31
    @hairymnstr, I just saw your post, very interesting that they use C++ to develop the program, and then convert it to spin. Now, I am wondering why nobody has made some changes to make it run on ICC, or Catalina? I guess not enough interest in C, would be my guess. I would need more details as to the differences between the C++ that the authors used, and ICC, before I would even consider a translation, this could be over my head. Would not be the first time. Anybody have any ideas?
    Ray
  • LeonLeon Posts: 7,620
    edited 2010-05-06 13:32
    I just tried running Perl on the script, and it generated what looked like a valid Spin file. If anyone else wants to try it, I used Strawberry Perl:
    strawberryperl.com/
    It writes to the console, so you need to use
    perl ctospin.pl fsrw.c > fsrw.spin
    to write the output to a file.
    It's C, not C++, BTW, but I don't know what compiler was used. The include files have non-standard names.
    Leon Heller
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 5/6/2010 1:42:04 PM GMT
    edited 2010-05-06 14:06
    On the other hand there are other FAT implementations written in C. I believe Catalina uses on of them.
    edited 2010-05-06 15:14
    I found the file where the authors mention that it was written in C, and tested using linux. Since this is proven code, I am wondering if it would be a worthwhile conversion project, to ICC that is?
    After looking at the fsrw.c code, I did not find any place where the pin assignments for a SD card adapter were hidden. But, since this is written to run on linux, then you are dealing with an SD adapter on the linux box. So, that would be the first thing to do, pin assignments for the SD adapter card. Still not sure as to the existing functions being able to run in the ICC environment; this could really show the portability of C, if they were able to run with minor tweaking. All suggestions are welcome as to how this conversion could take place.
    Since my "free" version of ICC has expired, can anybody guess as to whether the code that I would be dealing with would exceed the limits of the compiler, as it is now? I think the restriction is 4KB, if I am not mistaken. Now, before anybody says use Catalina, the object of this exercise would be, is to make it run using ICC.
    Ray
  • lonesocklonesock Posts: 917
    edited 2010-05-06 15:16
    There should be an included bat file to run the translator. And you are correct, the code is C (with some C++ style comments), however
    #include <cstdio>
    #include <cstdlib>
    #include <cstring>
    is the C++ version of those files...you may get it to work by changing those to
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    The code is just for testing, so I'm sure you'd have to add some extra code and play with the defines to get the C version to work on the prop. (You'll notice some things that are explicit Spin code, embedded into the C comments.) Only the higher level code is written in C then converted to Spin. The actual block driver is hand-coded in PASM, so you'd also need to duplicate that effort in C to actually communicate with the SD card.
    Jonathan
    lonesock
    Piranha are people too.
    edited 2010-05-06 18:19
    fsrw.c has a few C++ features in it, such as the include file names and variables defined within the body of a function rather than at the beginning.· It was also missing a closing brace in one of the functions, so it wouldn't have compiled even as C++.· I added a few #ifdef's and got it to compile under the Watcom C compiler.· It also compiles with gcc on Linux, but I had to rename popen and pclose because there was a conflict.
    The modified fsrw.c is attached below.· I tried running it, but it requires a properly formated SD image file called memcard to run.
    Dave
    c
    c
    32K
    fsrw.c 32.3K
  • rokickirokicki Posts: 1,000
    edited 2010-05-06 20:25
    Well, it assuredly compiles as C++ because that's how I test it. But no big deal. For sample use, see the "thrash.pl" file.
    edited 2010-05-06 20:46
    The function pclose seems to be missing a closing brace.· The compiler also warns that setdate and main don't return values, but that's not a big deal.· Do you have a sample memcard file that we could use, or is there a simple way to create one?
    Dave
    edited 2010-05-06 21:04
    The memcard file can be easily created on linux just by:
    1. Using dd to copy a raw mounted existing filesystem on a flash card to a file, or
    2. Using a loopback mount on linux to mount a file and create a FAT16 filesystem
    within that file.
    Wow, you're quite right of course about that missing brace. Must be a typo introduced
    somehow; I'll investigate when I get time.
    -tom
  • RossHRossH Posts: 5,550
    edited 2010-05-07 00:09
    @all,
    I didn't try the original, but Dave's modified fsrw.c compiles under Catalina (I had to make one additional change because the symbol 'fileno' conflicts with a macro in the Catalina libraries).
    However, since the program internally allocates a 12Mb array, there is no way it is ever going to run on any Propeller!
    Ross.
    Catalina - a FREE C compiler for the Propeller - see Catalina
    edited 2010-05-07 16:10
    rokicki said...
    within that file.
    The only linux systems I have access to are at work, and I don't think IT will give me the root password to do option 2.· I might be able to do option·1 if I can sneak into the server room and insert a flash card into one of the systems. [noparse]:)[/noparse]
    It seems like a formated SD card would contain a lot of zeros, and even a 1G disk image would zip down to a few kilo-bytes.· Do you have a freshly formatted memcard image that you could zip up and post?
    Dave
    edited 2010-05-07 16:48
    Note on using the C version *on* the prop: the C version contains a lot of code that's not part of the fsrw-spin package.
    Those routines (among other things) check the consistency of the filesystem. That's why it allocates the big array.
    The code is pretty short; it should be fairly clear what parts need to be on the prop and what parts don't.
    I'm attaching a memory card image. I created this image with the linux command:
    mkfs.vfat -F 16 -s 64 -C memcard 2000000
    The -F 16 says, create FAT16. The -s 64 says use 64 blocks per sector. The 2000000 says use 2000000 blocks (which
    is a lie; it actually uses 4000000 blocks; something's off by a factor of two in that program or something).
    To mount the filesystem so you can play with it on linux:
    mkdir mountpoint
    losetup /dev/loop1 memcard
    mount -t vfat /dev/loop1 mountpoint
    To unmount it:
    umount /dev/loop1
    losetup -d /dev/loop1
    To check consistency with fsrw:
    ./fsrw c
    To list files:
    ./fsrw l
    To create a file:
    ./fsrw w filename.txt < data
    To show a file:
    ./fsrw r filename.txt
    To delete a file:
    ./fsrw d filename.txt
    To append to a file:
    ./fsrw a filename.txt < data
    If you compile fsrw on a 64-bit machine, use -m32 to get a 32-bit compilation
    (the program casts pointers to ints). Or fix the code so it casts pointers to
    the appropriate type (the asint macro needs to be fixed; note that this code
    is only there so we can treat a pointer as an int in C; in Spin, there is no
    distinction).
    edited 2010-05-07 20:54
    Thanks for posting the memcard file.· I compiled fsrw.c with the Watcom compiler and it worked fine with the memcard file.· It's interesting that even with compression an almost empty 1.9 Gig file still produces a large ZIP file of 1.9 Megs.· For some reason I thought it would produce a smaller compressed file.· But it's hard to complain about a·1000 to 1 compression ratio.
    Also thanks for the explanation about the 64-bit pointers.· I noticed that gcc was warning about casting pointers to ints.· Now I understand why it didn't like that.
    Dave
    Dave Hein said...
    Thanks for posting the memcard file. I compiled fsrw.c with the Watcom compiler and it worked fine with the memcard file. It's interesting that even with compression an almost empty 1.9 Gig file still produces a large ZIP file of 1.9 Megs. For some reason I thought it would produce a smaller compressed file. But it's hard to complain about a 1000 to 1 compression ratio.
    I'm pretty sure that's a limitation of the representation...zipping the zip yields a 7KB file [noparse][[/noparse]8^)
    Jonathan
    lonesock
