Ribbon Cables
I am looking for a 6 conductor ribbon cable that is three inches long. They probably do not come in that length. I can find six conductor bulk wire but what type of connector is used that crimps down on the ends? What connectors for the PCB mount?
www.smarthome.viviti.com/propeller
you can get them from 4 way upwards.
I feel these are the best way for wire to board solutions for low power.
EG.
6 way vertical micromatch header latching..
au.mouser.com/ProductDetail/Tyco-Electronics/338068-6/?qs=TFNK99sdMfxDuat4QvJVjg%3d%3d
regards
Dave M
www.allelectronics.com/make-a-store/item/CON-243/3-PIN-CONNECTOR-W/HEADER-0.1//1.html
Cheapest is to cut old floppy and hard disk cables from old pcs.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
www.pololu.com/catalog/product/855
Edit: Don't know why it won't give the actual link?
Ah I think I got it now.
Post Edited (Propability) : 5/6/2010 7:37:19 PM GMT
I would request the latest Digikey catalog:
http://www.digikey.com/
They have a great selection of ready made ribbon cables and will make custom ones too. If if you don't use them this time their catalog will show a lot of different options and ideas for connectors and cables. They have a great selection of other parts too.
Robert
