Question regarding PASM
Hi all!
I splitted a PASM function into two parts:
Now if I want to call the whole function I'm using
but how do I call the sub function only?
I tried the following code but it does not work:
wINDIRECT 'Populate reg and data before calling this routine. 'and reg, _wordmask 'Ensure only a word will be copied over mov t2, reg and t2, _lowerbyte shl t2, shift1 andn outa, A0mask or outa, A1mask 'Set address to $02 (LSBs of address Register) or outa, RDmask 'Set RDpin high andn outa, WRmask 'and WRpin low to perform a write operation and outa, invDATAmask 'Clear all data lines or outa, t2 'set the data pins to the given value andn outa, CSmask 'Begin the data transmission nop or outa, CSmask 'End the data transmission (first half of the address) mov t2, reg and t2, _upperbyte shl t2, shift2 or outa, A0mask andn outa, A1mask 'Set address to $01 (MSBs of address Register) 'andn outa, CSmask 'Start the data transmission (second half of the address) and outa, invDATAmask 'Clear all data lines or outa, t2 'set the data pins to the given value andn outa, CSmask 'Begin the data transmission nop or outa, CSmask 'End the data transmission (first half of the address) :dataonly and data, #$FF 'Ensure only a byte will be copied over mov t2, data shl t2, shift1 or outa, A0mask or outa, A1mask 'Set address to $03 (data Register) 'andn outa, CSmask 'Start the data transmission (payload data) and outa, invDATAmask 'Clear all data lines or outa, t2 'set the data pins to the given value andn outa, CSmask 'Begin the data transmission nop or outa, CSmask 'End the data transmission (first half of the address) wINDIRECT_ret ret 'Return to the calling loop
call #wINDIRECT
call #wINDIRECT:dataonly
This way, you can call either wINDIRECT or dataonly
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
