Help with a sound effect device
I'm a senior in highschool, and am working on my senior project, a sound effect device. My idea was to have it work by pushing a two button combination (out of four buttons) which would then play back a sound. I haven't done any real BASIC programming before, although I was learning Ruby when I started working on this. When it came time for me to test out my programming, it predictably didn't work. I was wondering if anyone had any advice for me on it, or suggestions. I know my code structure is probably very bad, and I might be using some of the wrong commands
Theres a link to my device schematic here
http://yfrog.com/4vseniorprojectschematicp
Im using the Board of Education development board, and the SOMO-14D Audio Sound Module.
This is the link to the sound module page, and its data sheet (which is in a pdf format)
www.4dsystems.com.au/prod.php?id=73
www.4dsystems.com.au/downloads/Audio-Sound-Modules/SOMO-14D/Docs/SOMO-14D-DS-rev3.pdf
And here is the code I wrote
Edited to include info on development board and sound module.
Second edit to include updated code
Post Edited (Quornes) : 5/10/2010 3:28:44 PM GMT
'{$STAMP BS2} 'Stamp directive
'{$PBASIC 2.5} 'PBASIC directive
DEBUG "Program Running"
'----------{I/O}--------------------------------------------
Data1 PIN 1
Clock PIN 2
Reset PIN 3
Button_1 PIN 10
Button_2 PIN 11
Button_3 PIN 12
Button_4 PIN 13
'----------{SOHO 14D Audio Module Commands}-----------------
'Play/Pause FFFEh
'Stop FFFFh
'Volume FFF0h-FF7h (In terms of volume)
'Songs 0000h,0001h,0002h,0003h,0004h
'PIN 1 NEXT
'PIN 2 NC
'PIN 3 CLK
'PIN 4 DATA
'PIN 5 BUSY
'PIN 6 PLAY/STOP
'PIN 7 PREVIOUS
'PIN 8 VCC
'PIN 9 GND
'PIN 10 RESET
'PIN 11 SPK+
'PIN 12 SPK-
'PIN 13 NC
'PIN 14 AUDIO
'----------{Variables}--------------------------------------
volumechange VAR Byte
songselect VAR Byte
songplay VAR Byte
btnwork VAR Byte
Songfile VAR Word
Play VAR Word
Volume VAR Word
Song VAR Word
VolumeCheck VAR Word
'----------{Constants}--------------------------------------
BAUD CON 9600
SongDelay CON 10000
'----------{Initialization}---------------------------------
DEBUG "Initialization"
Songfile = 0
Play = 65534
Volume = 4087
Song = 0
VolumeCheck = 0
SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]volumechange]
SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Volume]
Restart:
DEBUG "Restart"
Songfile = 0
Song = 0
LOW Reset
GOTO Main
'----------{Program Code}-----------------------------------
Main:
DEBUG "Main"
GOSUB SubFileSelect
GOSUB SubFileSelect2
GOSUB SubSongSelect
SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]songplay]
SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Play]
PAUSE SongDelay
GOTO Restart
'----------{Sub Routines}-----------------------------------
SubFileSelect:
DEBUG "SubFileSelect"
BUTTON Button_1, 1, 255, 20, btnwork, 1, Main
Songfile = Songfile + 1
BUTTON Button_2, 1, 255, 20, btnwork, 1, Main
Songfile = Songfile + 2
BUTTON Button_3, 1, 255, 20, btnwork, 1, Main
Songfile = Songfile + 4
BUTTON Button_4, 1, 255, 20, btnwork, 1, Main
Songfile = Songfile + 8
RETURN
SubFileSelect2:
DEBUG "SubFileSelect2"
Songfile = Songfile + 10
Songfile = Songfile + 20
Songfile = Songfile + 40
Songfile = Songfile + 80
RETURN
SubSongSelect:
DEBUG "SubSongSelect"
SELECT Songfile
CASE 11
Song = 0
SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]songselect]
SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Song]
CASE 12
Song = 1
CASE 14
Song = 2
CASE 18
Song = 3
CASE 21
Song = 4
CASE 22
Song = 5
CASE 24
Song = 6
CASE 28
Song = 7
CASE 41
Song = 8
CASE 42
Song = 9
CASE 44
Song = 16
CASE 48
Song = 17
CASE 81
Song = 18
CASE 82
Song = 19
CASE 84
Song = 20
CASE 88
Song = 21
ENDSELECT
RETURN
IF Songfile = 1 + 1/2 THEN Song = 0 SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]songselect] SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Song] ENDIFThis part is almost exactly repeated many times and would be a good candidate for a subroutine. You could do a case to get the song number and then call the sub to play it, much less code and chance for errors.
Also a link to your sound chip would be helpful.
- Stephen
With the case command, would something like this work?
SELECT Songfile CASE 1 + 1/2 Song = 0 SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]songselect] SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Song] CASE 1 + 1/3 Song = 1 SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]songselect] SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Song]▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
- Stephen
SELECT Songfile CASE 11 Song = 0 CASE 12 Song = 1 CASE 14 Song = 2 CASE 18 Song = 3 ENDSELECT GOTO SongShiftIn SongShiftIn: SHIFTOUT Data1, Clock, MSBPOST ,[noparse][[/noparse]songselect] SHIFTIN Data1, Clock, MSBPOST ,[noparse][[/noparse]Song]▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
- Stephen
What I currently have is something like this.
BUTTON Button_1, 1, 255, 20, btnwork, 1, Main Songfile = Songfile + 1 BUTTON Button_2, 1, 255, 20, btnwork, 1, Main Songfile = Songfile + 2 BUTTON Button_3, 1, 255, 20, btnwork, 1, Main Songfile = Songfile + 4 BUTTON Button_4, 1, 255, 20, btnwork, 1, Main Songfile = Songfile + 8BUTTON command works like this
BUTTON Pin, DownState, Delay, Rate, Workspace, TargetState, Address
My problem is the Address part. Originally I thought setting it up the way I have it would change Songfile when the button was pushed, but after checking
"Back to the Basics (PBASIC) With Fun and Games" www.parallax.com/dl/docs/cols/nv/vol1/col/nv35.pdf
it seems that is not the case. Instead I would have to do something like this.
My question is there a way around doing the above code for each button pushed?
