Dead Ping)))
Hi
I need some troubleshooting help with the ping ultrasonic sensor, I had it running perfectly (impressive accuracy) for about 1 hour
As I touched the 7,5v connector to my propeller protoboard, to disconnect, I saw my DOGM display flicker, after that the Ping was dead.
I speculate, but really don't know, it got a transient voltage spike over the 5volt reg. No prob i thought and started checking resistors and caps, but they all seem fine. and no components running hot.
A bit weird really, other parallax components are quite rugged, and I have a hard time believing the on/off bounces when disconnecting the wallwart plug could kill anything.
Anyone know what the 4 test pads on the back of the ping is supposed to be. (2 of them are 5v and gnd respectively) 2 others are connected to the SX28 chip.
I haven't looked at any data sheets for the other 2 silicons on the board, but I assume they are opamps? Anyway, signal, gnd and 5v paths are okay up to all silicon parts.
Any hope or just scrap it and buy a few new ones?
Also do anyone know how well these work in a very acoustically noisy environment?
(going to use 4 pings or maybe just one, still considering that bit, to control 4 pneumatic actuators on a wood planer. Noise levels at about 110dB. The ultrasonics would be perfect if they tolerate the environment, dry, dusty, and very noisy. IR gives false signals on particles in the air, and stops working at all as dust settles on the lens, and going mechanical (switches and the like) is a last resort if this fails)
-H
-H
·a current spike can damge it.· Send me an e-mail at dandreae@parallax.com and we'll see what we can do?·
The Pings do not like dust, you'll want a dust free environment for the most part.· We don't have any data regarding the nosie, however, some electrical noise can cause the Ping to give back inaccurate readings.
Dave
Dave Andreae
Parallax Tech Support·
Parallax Engineering
(doh! of course, programming pads, not testpads, might have to read up on the SX then, like does it signal those data lines on powerup? so I could verify its not fried?)
