How to fill a DAT block conditionally - thanks, problem solved.
Cluso99
I have a screen buffer which varies in size. If it is greater than the cog space I need to fill past the end of the cog.
How do I do this only if the size > 496*4. The PropTool compiler fails if the amount to fill is negative (which is when I do not need to fill anything).
Here is the piece of code which fails.
The last line fails if (ocols*orows) < (496*4) however I want it to just ignore the command in this case.
If (ocols*orows) > (496*4) I want to reserve the extra bytes/longs.
Any ideas??
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
Post Edited (Cluso99) : 5/5/2010 9:05:50 AM GMT
'' │ The following fills cog space in hub + 16 bytes for screen[noparse][[/noparse]2000] space. │
long 0[noparse][[/noparse]$1F0-$] 'pad to fill cog space (because the screen lives here in hub)
ends FIT $1F0
org 0
long 0[noparse][[/noparse]((ocols*orows) -(496*4))/4] 'reserve extra space for screen > cog-size (1984)
Any ideas??
Maybe use a multiply in combination with the result of a comparison?
(((ocols*orows) > (496*4)) & %01) * ((ocols*orows) - (496*4)) + 1
What I'm thinking is that the comparison will either equal -1 or 0. And that to get just a binary 1 or 0. Multiply the difference between the needed screen memory fill value, and add one, just to keep the whole works positive.
8x8 color 80 Column NTSC Text Object
Safety Tip: Life is as good as YOU think it is!
Post Edited (potatohead) : 5/5/2010 5:34:54 AM GMT
@Phil: The buffer begins at the hub address where the cog is loaded from, so I am re-using the hub space after it is loaded into the cog. This works fine, but now I am making the screen buffer size variable so I need to allocate the extra little bit (if screen > 80*25) and I only want to allocate if it is required.
This is in my Debug 1pin TV * 1pin KBD code and I have almost all calculations now being done by constants so there is minimal overheads. I have also freed quite a bit of cog space for extra VT100 commands.
I have tried PAL 64*32 (2048) and it works nicely, as does NTSC 64*28, both at 5MHz. There is a little shimmering. 60* is a little better.
File attached: To archive I had to comment out the offending line in "Debug_1pinTV_rr051g.spin"
[b]CON[/b] BUF_LONGS = 100 [b]PUB[/b] start [b]cognew[/b](@my_cog, 0) [b]longfill[/b](@buffer, 0, BUF_LONGS) [b]DAT[/b] [b]org[/b] 0 buffer my_cog [b]long[/b] $aaaaaaaa[noparse][[/noparse]*200] 'This is the program. [b]fit[/b] [b]long[/b] $55555555[noparse][[/noparse]­(BUF_LONGS - $) & (BUF_LONGS > $)]Vary the size of BUF_LONGS, and use F8 to view the allocation.
Post Edited (Phil Pilgrim (PhiPi)) : 5/5/2010 6:56:01 AM GMT
Here is what I did, and I do not have to fill the cog space either if the screen is smaller. A winner all-round.
xeos long (ocols * orows) 'end of screen FIT $1F0 '' ┌──────────────────────────────────────────────────────────────────────────┐ '' │ The following fills cog/hub space (if reqd) for larger screens. │ '' └──────────────────────────────────────────────────────────────────────────┘ long 0[noparse][[/noparse](ocols*orows/4 > $) & (ocols*orows/4 - $)] 'reserve extra space if screen > cog code▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
The conditional math also helps in CAD. Not all systems offer comparisons and or are limited in syntax. Most will evaluate a comparison though. That's part of the convoluted expression I posted here.
Using the '&' like you did, eliminates the multiply needed to act on the compare, and makes more general logical sense than a simple value of "1" does to me now. Cool.
Post Edited (potatohead) : 5/5/2010 3:26:15 PM GMT
