Could pulsing DC prevent system overvoltage?
I am looking to use my .33hp electric motor to start the engine/generate power on my robot, however considering it runs on 12 volts 1750 rpm, connecting it to my engine at the max rpm which close to 5000rpm would generate ~36v. Although I may be able to do some short term charging of the battery at this voltage, it runs the risk of boiling the battery and frying my electronics tied to it. So, although I could use resistors and regulators to lower the voltage I really don't enjoy the idea due to the high energy loss. Instead I was wondering about pulsing the power to the battery, giving it too little time to build up voltage and keeping the system voltage around 14v doing so. Does this sound plausible?
Got 150 pounds of bot and growing.
Start with the Wikipedia article on Switching Regulators (en.wikipedia.org/wiki/Switched-mode_power_supply)
Cars don't suffer from this problem as they can modulate the field strength to adjust the output level.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
