Ping sensor in New Cog
My bot uses scripts that make my ping sensor pause for the duration of those functions. So i want to run the ping in a new cog. It runs for about 15 secons then gets stuck. The robot is all over the place (going left right backwards and god know where else!) for the same 15 seconds and then the program gets stuck.
what did i do wrong?
This is what i tried:
[noparse][[/noparse]code]cognew(PingCog(@distance), @PingStack)[noparse][[/noparse]/code]
and then...
[noparse][[/noparse]code]PUB PingCog(distance)
'Get Ping))) reading at all times.
······· repeat····
········· distance := ping.Centimeters(PING_Pin)············································ 'Get Range In Millimeters
········ long[noparse][[/noparse]distance] *= long[noparse][[/noparse]range]································ ' Ping value, store back
········ waitcnt(clkfreq + cnt)[noparse][[/noparse]/code]
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
and then...
······· repeat····
PUB PingCog(distance) 'Get Ping))) reading at all times. repeat distance := ping.Centimeters(PING_Pin) 'Get Range In Millimeters long[noparse][[/noparse]distance] *= long[noparse][[/noparse]range] ' Ping value, store back waitcnt(clkfreq + cnt)Do you really intend to overwrite the address of your distance variable with the range? And where/how is range (another address) defined?
example: IF range < 30
Turnleft
will that solve my problem or is this another problem i have?
repeat
range := ping.Centimeters(PING_Pin) 'Get Range In Centimeters
So what do i need to wrap around this code to make it run in a new cog and what value's do i need to use for calling the new cog in the main script?
Post Edited (kuroneko) : 5/4/2010 2:40:12 AM GMT
CON pin = 0 VAR long range long stack[noparse][[/noparse]40] OBJ ping: "Ping" PUB main cognew(PingCog, @stack{0}) waitpne(0, 0, 0) PRI PingCog repeat range := ping.Centimeters(pin) waitcnt(clkfreq + cnt) DATI use a ring buffer so that if I ignore the measurements for a long time I just discard the old ones and I do not run out of memory.
{{ Ping Minder Do a ping every.. blank.. seconds }} OBJ Ping : "Ping" CON MAX_BUFFER = 100 ' How many readings I save PING_ON = 1 PING_OFF = 0 VAR byte PingPin long PingDelay long cm long stack[noparse][[/noparse]512] long measure_ring_buffer[noparse][[/noparse]MAX_BUFFER+1] long servo_ring_buffer[noparse][[/noparse]MAX_BUFFER+1] long servo_ptr ' ptr to the servo position value in another piece of code byte PingOn ' 1 ping is on, 0 ping is off byte index byte cog PUB Init(pin, delay) PingPin:=pin PingDelay:=delay servo_ptr:=0 ' So I know I haven't set it PingOn:=1 index:=-1 cog:=cognew(Main, @Stack) return cog PUB SetServoPtr(ptr) servo_ptr:=ptr PUB GetServoPtr return servo_ptr PUB StartSweep ' Mark a sweep from one move to another repeat index from 0 to MAX_BUFFER-1 if (servo_ptr > 0 ) servo_ring_buffer[noparse][[/noparse]index]:=long[noparse][[/noparse]servo_ptr] ' BUT 109 WORKS, NOT SERVO PTR index:=-1 PUB GetIndex return index PRI Main repeat waitcnt(cnt+PingDelay) if (PingOn==PING_ON) cm:=Ping.Centimeters(PingPin) index:=index+1 if (index > MAX_BUFFER-1) index:=0 measure_ring_buffer[noparse][[/noparse]index]:=cm if (servo_ptr > 0 ) servo_ring_buffer[noparse][[/noparse]index]:=long[noparse][[/noparse]servo_ptr] PUB GetPingDistance return cm PUB GetPingAtLast(n) ' Get one of the recent pings, counting back n. n = 0 is the last ping if (index - n > 0) return measure_ring_buffer[noparse][[/noparse]index - n] else return measure_ring_buffer[noparse][[/noparse]index + MAX_BUFFER - n] PUB GetPingAt(n) if (n > -1) and (n < MAX_BUFFER) return measure_ring_buffer[noparse][[/noparse]n] PUB GetPanServoAt(n) if (n > -1) and (n < MAX_BUFFER) return servo_ring_buffer[noparse][[/noparse]n] PUB GetAverageDistance(num_measure) | loop, bindex,sum if (num_measure > MAX_BUFFER) or (num_measure < 1) return 0 ' You can't average more then you buffer or 0 sum:=0 bindex:=index ' backward index repeat loop from 0 to num_measure-1 sum:=sum+measure_ring_buffer[noparse][[/noparse]bindex] bindex:=bindex- 1 ' go backward if (bindex < 0) bindex:=MAX_BUFFER ' wrap it around if (num_measure > 1) return sum/(num_measure) else return sum PUB SetPingOn PingOn:=PING_ON PUB SetPingOff PingOn:=PING_OFF PUB Stop cogstop(cog)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
My Robots
That is great since that's just what i whas looking for.
But still my question raises..
Can you give me an example of how to run this in a sepparate cog?
I use the ping sensor for more tasks then one. So i want it to ping constantly ( every second or 0.5 second) and then the sensor values will be available even when the main script would stop reading because of other functions.
And is that per cog or for all cogs together?
