How to download a webpage into RAM buffer with PropNIC?
I have recently received my PropNIC and so as to not reinvent the wheel I was wondering if anyone had some sample code for simply downloading the web page (source) at a web address stored in a string? Then downloading straight into a RAM buffer for reading? The download can be all at once for it is not made for big webpages to be loaded. I am not knowledgeable of Ethernet works, so if you want to say some kind of AJAX or IP something or other, I may be clueless.
Thanks in advance,
Microcontrolled
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Thanks in advance,
Microcontrolled
It has a sample GET request and expected response about halfway down.
I would suggest you start by experimenting with a manual telnet connection to port 80 on the server you want to read from. Do something like this on your PC and see what come back:
I typed the code into command line (DOS) for testing and it returned an error. What did I do wrong?
Open a TCP connection to lwn.net on port 80.
Send the following lines:
Note the blank line at the end.
LWN replies with:
Followed by the web pages HTML content.
As I say it helps to experiment with this using telnet from a DOS box or from Linux first.
Replace "Replace "GET /" with "GET /whatever/page/you/want.html" for your own pages.
telnet lwn.net 80
at the command prompt and then when telnet says the connection is made type the "GET...etc..etc"
You might want to check how to use telnet under DOS I'm sure it's a little different way to give the port parameter.
Micro
I have no idea about the telnet object or PropNIC but I'm hoping it has a method to "open" a TCP connection to a specified server, probably using the IP address rather than the servers host name. There should be a way to specify the port number to connect to (80). Then methods to "send" some strings or lines and receive whatever comes back.
So "www.parallax.com" is the server name we are looking to connect to and the "http://" specifies the HTTP protocol which is generally operated on port 80.
Now to make the connection the browser has to find out the IP address of www.parallax.com, generally by asking a domain name server (DNS). The IP address happens to be "67.104.29.61".
Manually we can get the IP address by using the ping command from the DOS box or linux command line. For example try:
ping www.parallax.com
and it will reply:
PING www.parallax.com (67.104.29.61) 56(84) bytes of data.
Giving us the IP address we want in brackets.
Now often if a system allows you to use an "open" method with a server name string and a port number , say:
open ("www.parallax.com", 80)
one can replace the name with an IP address in the string like so:
open ("67.104.29.61", 80);
I hope your PropNic has this same idea.
