engine run backwards?
P!-Ro
Hey I'm curious, I have a 1/3 hp motor I am interested in using as a starter/generator for my robot (seen in avatar) and I was curious as to whether it could actually start the engine backwards in order back-up. It seems alright thinking about it, the only seemingly different thing would be where the electricity flowed from on the spark plug. However, I do not know about other issues such as if the valves would be messed up with the engine running the other direction, and the flow of oil through it. Anyone with extra experience wish to help me out?
Got 150 pounds of bot and growing.
Leon Heller
Amateur radio callsign: G1HSM
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
If you are using a conventional centrifugal pinion starter you might be SOL though.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
Leon Heller
The linkage changed the ignition timing to the other side of TDC .
As for the Bot, I'd think 1/3hp might be a bit small without some serious gearing for starting which could lead to over-speeding the motor when the engine does start and rev up.
Tom Sisk
http://www.siskconsult.com
Leon Heller
Rich H
www.youtube.com/watch?v=ebvD1RnX7LY&feature=related
I think that if I was in your position, I'd use the engine to turn a alternator, then use the electricity from the alternator to power the bot and power motors to turn the wheels. If you use an H-bridge the motors will be reversable AND, if you get really ambitious, you could use the alternator to charge a battery, and only run the engine when you need extra juice for the motors or when the battery needs charging.
Never give up,·Never submit to the seemingly invincible enemy.
JS-KB3RBR
So I would take that as a very big indications that it would be very difficult to make this happen as another posted pointed out it would have to suck through the exhaust and blow out through the EFI the 2 stoke engine is a completely different animal
I know nothing about RC gas engines I would be curious myself if they can run backwards
I would think that as long as the oil pump is working, running it backwards would not be that big of a deal. With propper spark timing the effencies would be better.
Signature space for rent!
Send $1 to CannibalRobotics.com.
A typical glow fuel RC engine does not use a reed valve. It uses a rotating cylinder which is part of the crankshaft. I have had them run in reverse, but not very well. I think that it because the intake port on the rotating valve is timed to one side.
A gasoline RC engine does use reed valves, and if it also uses electronic timing then it would be really easy to add one more sensor on the other side of TDC and just switch to the appropriate one when you want to change direction.
Rich H
You didn't mention the size of the engine but because the motor is only 1/3 HP I don't think my Idea mentioned below would be applicable but I'll post it anyway.
looking at the drawing below notice;
The engine can only turn the drive shaft when the electric clutch #1 is
energized.
The motor-generator shaft is directly connected to the floating drive shaft and the #2 electric clutch
turns the drive sprocket when energized to·turn the wheel sprocket by chain.
1. Electric clutch #1 when energized is for generating electricity or
starting the engine.
2. Electric clutch #2 when energized is for turning the drive sprocket
forward or reverse with the motor-generator, that's necessary for going in
reverse.
3. Electric clutch #1 & 2 when energized are for turning the drive sprocket
with the engine and possibly motor assist or generating electricity with the
motor-generator.
I think my idea is somewhat of an invention because for some reason electric clutches aren't in widespread use outside of automotive air conditioning and garden tractors as far as I know so I've never seen anything else like it.
Post Edited (AJ-9000) : 5/6/2010 1:18:22 AM GMT
