need help with ping sensor
i have been trying to use the ping))) sensor with the usb propeller, i have tried to get it to work with a demo ping program and i have tried to get it with one i wrote and no matter what i try i cannot get the ping sensor to turn on and work. i attached a modified program that i made·and i was wondering if someone could help me by looking at my program and telling me if there are any problems with it? please, i need the sensors to work for a school project that i am doing.
It might be helpful if you described the board you are using to connect it to (and how), or even better still a picture. I have used a Ping with a prop like a zillion times on robots, it works great. Let me help you make it work.
My Robots
If you mean the usb protoboard, then in the top right corner there are four sockets for servos that you can hook into the regulated 5v supply. This is a great way to run a ping sensor.
The two big things to be concerned with a Ping in my experience is don't hook it to a circuit with too much voltage. I have wrecked a couple by hooking them directly to a 7.2v battery. The second thing is that like servos they can cause a brown out if you have low battery or weak power supply. If you burn out a Ping from too much voltage, it will not light up when it gets a signal and it has the appropriate power. It will also not light up if it is not getting enough power. If you have a brown out, your code will load, run, and at the moment the Ping is about to fire your program will reset (assuming there is something in EEPROM).
My Robots
My wife is very, very understanding
