Small Audio Emitter
Hello everybody, I'm new to the forum but have used Parallax products before in courses. I would like to create a small scaled device that plays small audio clips at set times (It's supposed to be really basic). I'm not sure where to get started but I just need that initial push and a brief explanation of what I need. I'm not sure if any Parallax product can play a small mp3 or wma audio clip. If this can't be done with Parallax products, could someone provide some alternative insight on where to begin? The materials I currently have is the Basic Stamp Kit. I can get more items as needed. Thanks so much!
Vinculum sells their VMusic2 which uses USB memory sticks for storage. I've used it with both a Stamp and the Propeller and haven't had any problems although others have complained about not being able to get it to work.
Post Edited (Mike Green) : 4/30/2010 3:35:00 PM GMT
There are all sorts of Propeller boards to choose from. A Demo Board would have the stereo headphone output as well as video output if you want to use that for debugging. It's just missing the SD card socket which you can get from Parallax as a little piggyback board that plugs into the breadboard socket on the Demo Board. I've used the micro SD card socket "breakout board" from SparkFun which is smaller and mounts flat against the breadboard socket.
My ultimate plan is to have the device at it's smallest size including battery, speaker, etc and play a .wav (alarm beeping or so) at certain hours in the morning. I tried looking around for such projects but it's hard to conduct a search that gives the results I'm looking for. So any tips or information would be greatly appreciated.
Thanks again for all your help so far!
Heck with that said, the earliest speech synthesisors used a bare minimum of resources (memory and processing power) and some smart people..... although I wouldn't want to tackle it!
"puff"...... Smile, there went another one.
