VGA does not look too MOUSE — Parallax Forums
Ahmet YILDIZAhmet YILDIZ Posts: 4
edited 2010-04-30 13:12 in Propeller 1
Hello
I've got a problem
Propeller with a mouse and a monitor I want to use low resulation
I've done in the example works in a normal mouse X, Y kordinatlarını can read, can read Nang button is pressed but the mouse does not appear on the screen.
"VGA_1280x1024_Tile_Driver_With_Cursor" sample program is working with the same routine, but my mouse low resulasyon and letters should be large.
I would be glad if it helps.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
cols = 80
rows = 64
tiles = cols * rows
spacetile = $220
VAR
long col, row, color
long boxcolor, boxptr
long array[noparse][[/noparse]tiles/2]
long cursor[noparse][[/noparse]1+32]
long cursor_x, cursor_y, cursor_col, cursor_def
OBJ
text : "vga_text"
mouse :"mouse"
PUB start | i,flag , Flag2
text.start(16)
'start mouse and set bound parameters
mouse.start(24, 25)
mouse.bound_limits(0, 0, 0, 799, 639, 0)
mouse.bound_scales(1, -1, 0)
mouse.bound_preset(400,320,0)
repeat
'set mouse cursor according to area
cursor_def := 1 '0
cursor_col := $FC 'F0
'update mouse position
cursor_x := mouse.bound_x
cursor_y := mouse.bound_y
text.str(string($A,7,$B,7,"X := "))
text.hex(cursor_x,4)
text.str(string($A,7,$B,8,"Y := "))
text.hex(cursor_y,4)
text.str(string($A,7,$B,9,"Button := "))
text.hex(mouse.buttons,2)
  • RaymanRayman Posts: 16,070
    edited 2010-04-30 12:33
    vga_text doesn't inherently support a cursor, is that the problem?
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
    Ahmet,
    When you post samples of your code, paste your code between these two tags except remove ALL of the empty spaces
    [noparse][[/noparse] code ]
    [noparse][[/noparse] / code ]
    That way your code
      will preserve
        the proper indentation
    It seems to me that your REPEAT loop should have some code that tells it to read the mouse position on every loop. Does mouse.bound do that?
    Post Edited (ElectricAye) : 4/30/2010 1:27:03 PM GMT
