Access to GOSUB return address on BS2E
In the Basic Stamp 1 W6 held the return address after a GOSUB.· I'm wondering if on the Basic Stamp 2E if there's a way to access the GOSUB return address?· What I would like to do is in my main module call a TaskDispatch
TaskDispatch:
· ' Store GOSUB return address in the Scratchpad
· PUT 0, Word·W6··· ' I know its not W6·on the BS2E
· PUT 2, TaskIndex
· RUN TaskBank
At the head of the main module I would see if there was a return address at 0 in the scratch pad and then load it into the location that holds the GOSUB return address. I would then execute a return so I could resume program execution where· I called TaskDispatch.
· Task = TaskReadLine
· GOSUB TaskDispatch
· ' More stuff after the GOSUB
If there's no way to access the GOSUB return address I have another way to do it using GOTO's and a BRANCH at the head of the module.· It would be much cooler with access to the return address.
TaskDispatch:
· PUT 2, TaskIndex
· RUN TaskBank
The Stamp2 uses an indexed stack scheme similar to the BS1. The stack does not hold the actual return address, rather, it holds an index into a table of return addresses that are stored at the top of the eeprom program memory.
Tracy Allen
www.emesystems.com
