Using the CRC calculator
I am creating my own program to transmit and receive data with the Parallax RF module. All I need is to add a CRC check (this is where I am in a snafu), and I can finish the rest. I downloaded and tried Beau's RF demo and it includes a CRC check. I am writing my own handshake algorithm. I looked at Beau's code and found working with the CRC object is a little tricky. For my code I need to know how to (see my program comments) using Beau's CRC:
Properly calculate and send the CRC.
Receive the CRC and validate it.
My program does successfully send data using straight RS-232. All I need to do now is packetize the data and implement the CRC and all should work fine.
kt88seamp [noparse]:)[/noparse]
Signature space for rent!
Send $1 to CannibalRobotics.com.
Post Edited (CannibalRobotics) : 4/29/2010 9:51:35 PM GMT
http://forums.parallax.com/showthread.php?p=902959
Not all the code is there. Where is the portion that receives the data and validates the CRC?
This is the transmit peice - it sends a 16bit·CRC byte pair at the end of the packet, reversed and inverted. You don't have to go to that trouble - it's device specific.
The receive component would work similarly in that you would initialize the '_crc'·to $FFFF, cycle each new byte arrival through the updatecrc routine and when you have counted enough bytes - look to see if your calculated·CRC matches the transmitted CRC at the end of your arrived packet.
Let me know how it goes.
cheers
Jim-
Pub SendText(Line,ptr) | _crc,crch,crcl,i,size,PacketSize ' This code has some overhead for clarity and readability ' Line: is a device specific command and just inserted into Packet 0 ' ptr: is a string pointer for an ASCII string to be sent as the payload ' the packet structure is: <command><PayloadSize><packet[noparse][[/noparse]0]...packet[noparse][[/noparse]packetsize]><!crcL><!crcH> PacketSize := 17 ' initialize packer size - inclued 0 size := strsize(ptr) ' get length of string _crc := $FFFF ' initialize _crc ' Start process of building 18 packet byte <<i = 0 to 17>> ' Build packet 0 if Line == 1 ' if line number 1 then CF command is 6 Packet[noparse][[/noparse]0] := 7 if Line == 2 Packet[noparse][[/noparse]0] := 8 ' if line number 2 then CF command is 7 ' Build packet 1 Packet[noparse][[/noparse]1] := PacketSize - 1 ' Calculate remaining data payload size for packet 1 ' Build packet 2 - 17 repeat i from 2 to PacketSize ' set next PacketSize bytes to string byte values or spaces if i < (2 + size) Packet[noparse][[/noparse]i] := byte[noparse][[/noparse]ptr + i - 2] else Packet[noparse][[/noparse]i] := 32 'dec 32 is the 'space' charactor for empty text ' Packet now built ' so loop through & calculate _crc, send byte by byte Repeat i from 0 to PacketSize 'Send front of packet _crc := UpdateCRC(Packet[noparse][[/noparse]i],_crc) ' Calculate crc in the loop TSc.tx(Packet[noparse][[/noparse]i]) ' send the byte ' Finished sending packet here so wrap up by sending crc low and high ' Watch the MSB/LSB order and inversion here - can be tricky crcl := !(_crc & $00FF) ' Bottom 8 bits into crc low & invert crch := !(_crc >> 8) ' Top 8 bits into crc High & invert TSc.tx(crcl) ' complete transmission with last two bytes TSc.tx(crch) Pri UpdateCRC(data,crc):newcrc|i,icrc ' CRC calculation engine ' SPIN adapted from CrystalFontz generic 'c' algorythm ' data: 'new byte' or next byte in packet ' crc: running crc mantained in calling pub/pri Repeat i from 0 to 7 if ((crc ^ data) & $01) crc := crc >> 1 crc := crc ^ $8408 else crc := crc >> 1 data := data >> 1 return crc & $FFFF▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Be careful on the byte count - it's easy to get it confused.
J-
