Melexis 90217 RPM sensor NEED HELP PLEASE!!!
I am using a parallax Melexis 90217 RPM sensor on a windmill. the rpm data is transported to the basic stamp and then the motor controller will spin the motor the same speed as the windmill is turning. Im just not sure how to talk to the Melexis 90217 RPM sensor or let it talk back to me. I found the data sheet on parallax website on how to wire it up. I just need some help on the code used to use the sensor. Anyone used this sensor before or know what kind of code to use!!??!?!?!
any help would be greatly appreciated!!
Justin Iverson
UMD
Sculpture and Ceramics Major
Justin Iverson
UMD
The Melexis 90217 is a hall effect sensor. There is no talking to it, per se. All it will do is pulse its output in relation to a magnetic field near it. If you are trying to get RPMs you would generally count pulses within a specified time interval, such as 1 second, using the COUNT command. You could then use that to calculate RPM. For more information please see the following link.
http://www.parallax.com/ProductInfo/Robotics/MachiningTips/BASICMachiningRPMDisplayforyourMill/tabid/420/Default.aspx
Parallax Engineering
http://forums.parallax.com/showthread.php?p=903628
