unable to mount SD card — Parallax Forums
Patrick1abPatrick1ab Posts: 136
edited 2010-09-30 13:48 in Propeller 1
Hi all!
I know that I've seen a similar thread once, but I couldn't find it anymore (even with the search function).
After changing the I/O Pins of my Propeller/SD card interface from
DO 16
CLK 17
DI 18
CS 19
to
DO 12
CLK 11
DI 10
CS 9
I am not able to mount an sd card anymore.
I checked all the solder joints: They are all connected and there is no short circuit.
I'm using pull up resistors (as I always do) and even shortened the cables a bit.
The fsrw version I use is 2.6.
What I recognize is, that it takes quite a while (a second or 2) before the mount function returns an error.
The error code which is returned is -100, so according to the table it's ERR_ASM_NO_READ_TOKEN.
Please try to help me, if you've got an idea what the problem could be.
Thanks!
Patrick
  • hairymnstrhairymnstr Posts: 107
    edited 2010-04-29 10:28
    Hi Patrick, can you post some code. I don't think we can figure anything out from that description I'm afraid.
    Nathan
    "Free as in freedom, beer gratefully accepted though."
  • Patrick1abPatrick1ab Posts: 136
    edited 2010-04-29 10:59
    Hi Nathan,
    thanks for your quick reply.
    I put the code in the attachments, but I'm not sure if you can find the problem in there.
    I only changed one line in the "checkforSD" procedure of the "Main.spin" file:
    from
    temp:=\sdfat.mount_explicit(16,17,18,19)
    to
    temp:=\sdfat.mount_explicit(12,11,10,9)
    Maybe I'll try to hook up my oscilloscope to see whether the signals are distorted somehow.
    edited 2010-04-29 12:11
    You're right, I can't see anything wrong there. It makes me suspicious of (a) hardware or (b) the dreaded cog order problem.
    What has happened when you switched the pins is the I/O "distance" has got longer for high numbered cogs. Since the fsrw object is one of the later cogs to start up it is probably in a high numbered cog (I haven't counted). This means it is closer (in terms of OR gates) to the pins 16-31 than 0-15. So using the fsrw code which runs at 20MHz the propagation delay/current draw is causing you problems I suspect. Other people have had this problem. One solution is to start the cog up as the first object (this puts it very close to the output pins) another is to use a slower block access layer. I have written one (it's in DracBlade_spi.spin) but it's not very portable, it also doesn't support HCSD so if you can get the mb_raw_spi version to work, that would be best.
    Nathan
    edited 2010-04-29 16:37
    hairymnstr said...
    I'm going to try that. It would be great, if this is the solution.
    Meanwhile I did some measurements with my oscilloscope and saw that my CLK-Signal wasn't as nice, as it should have been.
    Some kind of capacitance (see the purple signal on the first picture)
    I renewed the solder joints and as you can see in the second picture now it looks much better.
    Another thing which bothered me is the echo I had on the DO-Line (green signal); maybe the connections are still too long.
    I was able to clean this a bit by adding a pull down resistor.
    As the problem still persists, I am going to start the fsrw cog first.
  • rokickirokicki Posts: 1,000
    edited 2010-04-29 17:25
    Wait, that scope picture: what are the three waveforms?
    If two of them are outputs from the prop, there are clearly setup/hold violations going on there.
    Would you be willing to get the same picture, but using the original pins?
    We may be on to something here.
    edited 2010-04-29 17:35
    In fsrw.spin I see:
       'sdspi: "safe_spi"
       sdspi: "mb_rawb_spi"
    That is, you are using the fastest, hottest, driver there. Can you switch to the safe driver
    by changing it as follows:
       sdspi: "safe_spi"
       'sdspi: "mb_rawb_spi"
    and let me know if that solves it, and/or if that changes your scope pictures in any way?
    edited 2010-04-29 18:12
    Hi Tomas,
    thanks for your reply.
    This is really weird:
    I switched to the safe driver and it works perfectly. Switching back to the high speed driver, I've got the same problem as before.
    Now it's even getting more confusing :-D : Have a look at the signals (Picture 1 is the safe driver, Picture 2 the high speed version)
    If there is a setup/hold violation, then this exists in both drivers, doesn't it?
    CS: yellow signal
    DI: blue signal
    CLK: purple signal
    DO: green signal
    edited 2010-04-29 18:34
    Howdy!
    No, this is starting to *perhaps* make more sense. Are these both using the 12-9 pin set?
    Looking at your images, things are probably just fine, although it's hard to know precisely
    what portion of the protocol is pictured in your images. The thing is, your time frame is, if
    I'm interpreting it correctly, 10us/div, so setup/hold would be *much* too small to show up
    at that temporal resolution. In both pictures, that portion of the protocol is probably working
    fine; the failure is probably occurring much later.
    For your purposes, would the safe driver suffice? It's not *that* much slower.
    -tom
    edited 2010-04-29 18:57
    rokicki said...
    Yes, both are using this pin set. Sorry, I was too lazy to change it again...
    rokicki said...
    The portion of the protocol you see, are the very first bits the driver is sending when the mount_explicit function is called.
    rokicki said...
    At the moment (for testing purposes) I can live with the slower version, but I'm eager to find a solution so that I can get the high speed driver working aswell.
    edited 2010-04-29 20:16
    hairymnstr said...
    You were right. If I start fsrw first and afterwards the other objects, it works just fine.
    Now I have to find a way to "reserve" a cog or start the SPI driver of fsrw without mounting an SD card, since the other objects have to start even if there is no SD card inserted at the beginning.
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-04-29 20:36
    Simply start an empty loop in the COG at the very beginning. Then you can modify the SD driver a little bit and use COGINIT instead with the COGID of the empty-loop-COG.
    edited 2010-04-29 20:38
    The performance difference is probably not so great. Benchmark it with both versions and see if you want to complicate
    things just to use the fancy driver. The "simple" driver is actually a crowning achievement of engineering and does
    very, very well.
  • SzabiSzabi Posts: 58
    edited 2010-09-30 12:38
    Hi Guys!
    Me too I'm having problems mounting my SD card. I was trying to use 2GB and 16Mb ones as well.
    I'm using CS, DI, SCLK, DO on pins 16-19 with 10K pullups to 3.3V (unused data pins are connected to 3.3v through 10K pullups), booth vss are connected to GND
    Take a look at the output of test.spin form the object exchange.
    It will fail with both hi or slow speed drivers.
    The first test are ok but it looks like it fails during "mount_explicit"
    Mount tests first
    First mount.
    Succeeded; stopping cog.
    Second mount.
    Succeeded.
    Reading block 0 (should be a boot block)
    Read finished; checking for boot block signature
    Boot block checks out; unmounting
    Third mount.
    Succeeded.
    Reading block 0 again (should still be a boot block)
    Boot block checks out; writing it back
    Write finished; unmounting
    Fourth mount.
    Succeeded.
    Block layer seems to check out
    Now speed tests
    How fast can we write, sequentially?
    Do a single non-sequential write...Done/s
    How fast can we read, sequentially?
    Now the filesystem tests ms at 1359 kB/s
    Trying to mount
    Erroneously returned from start!
    -20
    does anyone have an idea?
    Thanks in advance!
    edited 2010-09-30 12:54
    hairymnstr wrote: »
    What has happened when you switched the pins is the I/O 'distance' has got longer for high numbered cogs. Since the fsrw object is one of the later cogs to start up it is probably in a high numbered cog (I haven't counted). This means it is closer (in terms of OR gates) to the pins 16-31 than 0-15. So using the fsrw code which runs at 20MHz the propagation delay/current draw is causing you problems I suspect.
    I'm having SD card mounting problems myself and just noticed this old message. Is it really true that there are electrical differences between I/O pin access by different numbered COGs? Is this a silicon bug on early Propeller chips that has been fixed in ones manufactured more recently? Does anyone have a list of these "silicon errata"?
    edited 2010-09-30 13:10
    David,
    If you look at the pictures of the Prop I chip, you'll see that the I/O pin pads are located along the periphery of the chip while the cogs themselves are located across one dimension of the chip. There's also a block diagram of the Prop I on the Propeller Downloads web page that shows how the I/O pins are chained together functionally. The net result is that there's a short delay (I think on the order of maybe 2ns-4ns) for the I/O signal on the "far end" of the chip as compared to the one closest to the I/O pad. This is not a "silicon errata". It's simply a result of the deliberate design of the I/O structure of the Prop including the gate delays involved in the chain of OR gates. It could be "fixed" by completely redesigning the I/O structure to balance the timings from one cog to another. There would still be differences, but they would be smaller and it would be a major redesign of the chip. Considering that the instruction execution time is on the order of 40ns to 50ns and the system clock time is maybe 10ns to 12.5ns, you're talking about small fractions of the basic clock time of the device.
    edited 2010-09-30 13:15
    Thanks for the explanation. That makes sense. I didn't expect the delays to be exactly the same for all COGs. I thought the original poster was trying to say that certain COGs would not be able to reliably operate certain pins. That would be unfortunate.
    edited 2010-09-30 13:25
    It sounds like the SD card needs to be as close to the Propeller as possible when using the slightly faster mb_rawb_spi version of the SD card driver. When using the safe driver does anyone know how far away the SD card reader can be from the chip? I have a project where the speed of the safe version would be fast enough but I really need to locate the SD card adapter about 12" from the Propeller chip. Has anyone connected an SD card in a similar way where it isn't near the Propeller? If so how did it work for you?
    Robert
  • KaosKiddKaosKidd Posts: 296
    hairymnstr wrote: »
    What has happened when you switched the pins is the I/O 'distance' has got longer for high numbered cogs. Since the fsrw object is one of the later cogs to start up it is probably in a high numbered cog (I haven't counted). This means it is closer (in terms of OR gates) to the pins 16-31 than 0-15. So using the fsrw code which runs at 20MHz the propagation delay/current draw is causing you problems I suspect. Other people have had this problem. One solution is to start the cog up as the first object (this puts it very close to the output pins) another is to use a slower block access layer. I have written one (it's in DracBlade_spi.spin) but it's not very portable, it also doesn't support HCSD so if you can get the mb_raw_spi version to work, that would be best.
    Nathan
    'Free as in freedom, beer gratefully accepted though.'
    Ok, this might sound silly, but if it's a known issue that the cog number affects the timing, have the code retrieve it's cog number and make it automatically adjust the timing. It can't be that much of an effort to make it work like that.
    Just my humble opinion...
    KK
