detecting positive versus negative voltage
·I have a device that controls a small·motor.·It has intricate·circuitry which·I find hard to read. ·It·drives the motor using two wires with 5 volts accross.· The charge changes direction to rotate the motor clockwise or counter clockwise.
My objective is to detect the charge change by using BS2 and operate a much larger motor using hb-25 motor controller.
Can someone help me build a circuit diagram showing this device connection to BS2 and HB-25. Also what code or instruction should I use to read the voltage from BS2?· Do I need any other IC or components for this? I will also appreciate·if you have·links you can share to similar projects or topics.
Post Edited (gablor) : 4/29/2010 4:33:16 AM GMT
· Nonetheless, I think I have grasped the basics of what you are trying to do.
· By using 2, ·5-volt relays ( SPDT) with contacts rated for the bigger motor, plus a few diodes, you can implement your requirements pretty easily.
· I've attached a sketch of what came to mind.
Tom Sisk
http://www.siskconsult.com
