Going wireless — Parallax Forums
Going wireless
GrampsGramps Posts: 117
edited 2010-04-29 06:19 in BASIC Stamp
My project has 8 servos plus some switches.
To go wireless it looks like I need 2 B-Stamp platforms and two 433 MHz RF Transceiver modules. Is that correct?
Are there other alternatives from Parallax?
    edited 2010-04-29 01:36
    Distance? XBee might be an option.
    - Stephen
  • GrampsGramps Posts: 117
    edited 2010-04-29 01:54
    150 feet but will have to travel through some walls.
    edited 2010-04-29 02:09
    The higher power (PRO) xBee modules should work. The Parallax transceivers might work, but they're good for at most 250 feet in open air. Whether that's equivalent to 150 feet with walls in the way or not is anybody's guess and depends partly on what's in the walls. Another advantage of the xBees is that they do their own error checking and retransmission. You have to include that in your program if you use the Parallax Transceivers.
    edited 2010-04-29 02:18
    Yes, and over all the xBee system looks cheaper too.
    Which Stamp board should i get to make a system?
    (Have a Homework board now)
    Would that BS1USB board work?
    Post Edited (Gramps) : 4/29/2010 3:04:45 AM GMT
    Gramps said...
    Which two BS2's should i get to make a system?
