Project issue
jknightandkarr
Here's my program first of all.
My problem is, vss:=67 give me the desired display, but when I disable it to use
Dira[noparse][[/noparse]12]:=0 'Start counting vss signal
ctra:=0
ctra:=(%01010<<26)|(%001<<23)|(0<<9)|(12)
frqa:=1
phsa:=0
waitcnt(80_000_000+cnt)
vss:=phsa 'Send speed sensor value on.
ctra:=0
All I get is random numbers from my speedsensor & the speedbuffer system, which is from an 89' Trans-Am 700R4, the numbers continue even with my speed sensor stopped. I got an analog electric speedometer from a Firebird I have hooked up with the propeller, so the speedsensor & buffer works fine. I tried looking the counter program over, but I don't quite fully understand the programming. I got it from the BS2 Functions list from the propeller object exchange. What's my problem?
Joe
I'm going insaine. It's SOOOOOO much fun. lol
Post Edited (jknightandkarr) : 4/28/2010 6:27:53 AM GMT
{{Vehical Speedometer Display.
8K or 4K Pulses Per Mile sending units
Displays Kph=Kilometers Per Hour or Mph=Miles Per Hour
By: Joe R on March 16th, 2010
CON
_clkmode =xtal1+pll16x 'system clock
_xinfreq=5_000_000 'set 80 Mhz
isEnabled = %0001
VAR
long LowDigitPin, HighDigitPin 'The pins for specifying digits.
'Must be contiguous
'HighDigitPin can be from 0 to 7 more than LowDigitPin
long Seg0Pin, Seg8Pin 'The pins for the segments.
'Must be contiguous
'Segment 8 is the decimal point
long flags
long myStack[noparse][[/noparse]10]
long runningCogID
long myValue 'Value to be displayed
long vss 'Vehical Speed Sensor Input
long Mph 'Display In Miles Per Hour
PUB Speed(dLow, digits, s0, enabled)|kph
'' Start the display
'' Parameters:
'' dLow - the pin number of the least significant digit
'' digits - the number of digits to display (up to 8)
'' s0 - the pin number of segment 0
'' enabled - the initial enabled state
dira[noparse][[/noparse]13]:=0 'Set pin 13 as input
repeat
ctra:=0
frqa:=1
phsa:=0
ctra:=0
'vss:=67 'Temporary Speed sensor value
If ina[noparse][[/noparse]13]==0 'Look for Pin13 for 1 or 0
Mph:=vss*9 'Calibrate for 4000ppm sender if pin 13=Low
else
Mph:=vss*9/2 'Calibrate for 8000ppm Sensor if pin 13=High
If ina[noparse][[/noparse]14]==1 'Check for Mph or Kph setting
Kph:=Mph*1_609_344/1_000_000 'Display speed in Kph
else
Kph:=Mph*1 'Display speed in Mph
myValue := Kph 'Copy Kph to myValue
LowDigitPin := 8
HighDigitPin := 8 + ((4 - 1) <# 7) 'Limit to eight digits
Seg0Pin := 0
Seg8Pin := 0 + 7
dira[noparse][[/noparse]Seg0Pin..Seg8Pin]~~ 'Set segment pins to outputs
dira[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'Set digit pins to outputs
outa[noparse][[/noparse]Seg0Pin..Seg8Pin]~ 'Turn off all segments
dira[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'Turn off all digits
' if enabled 'Set initial enabled state
flags |= isEnabled
'else
'flags~
stop
runningCogID := cognew(ShowValue, @myStack) + 1
PUB Stop
'' Stop the display
if runningCogID
cogstop(runningCogID~ - 1)
PUB Enable
'' Enable the display
flags |= isEnabled
PUB Disable
'' Disable the display
flags &= !isEnabled
PUB SetValue(theValue)
'' Set the value to display
myValue := theValue
PRI ShowValue | digPos, divisor, displayValue
' ShowValue runs in its own cog and continually updates the display
repeat
if flags & isEnabled
displayValue := myValue 'take snapshot of myValue so it can't be changed
' while it is being displayed
divisor := 1 'divisor is used to isolate a digit to display
repeat digPos from 0 to HighDigitPin - LowDigitPin 'only display as many digits as there are pins
outa[noparse][[/noparse]Seg0Pin..Seg8Pin]~ 'clear the segments to avoid flicker
outa[noparse][[/noparse]LowDigitPin..HighDigitPin] := byte[noparse][[/noparse]@DigSel + digPos] 'enable the next digit
outa[noparse][[/noparse]Seg0Pin..Seg8Pin] := byte[noparse][[/noparse]@Digit0 + displayValue / divisor // 10] 'display the digit
waitcnt (clkfreq / 10_000 + cnt) 'the delay value can be tweaked to adjust
' display brightness
divisor *= 10
else
outa[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'disable all digits
waitcnt (clkfreq / 10 + cnt) 'wait 1/10 second before checking again
DAT
'Common cathode 7-segment displays are activated by bringing the cathode to ground
DigSel byte %11111110
byte %11111101
byte %11111011
byte %11110111
byte %11101111
byte %11011111
byte %10111111
byte %01111111
'.GFEDCBA
Digit0 byte %00111111
Digit1 byte %00000110
Digit2 byte %01011011
Digit3 byte %01001111
Digit4 byte %01100110
Digit5 byte %01101101
Digit6 byte %01111101
Digit7 byte %00000111
Digit8 byte %01111111
Digit9 byte %01100111
ctra:=0
frqa:=1
phsa:=0
ctra:=0
Joe
Ok, I don't know why the code option took out all my extra indentations, so rather then fight with it all nite, I'll just post the program directly.
Joe
Yeah it takes the formatting out sometimes. It's a pain.
Without looking at your code, I would bet that you are getting electrical noise that is causing the random value.
Are you running the Propeller from the car battery ?
Can you post a schematic of your buffer ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
Buffer......I can try, depends if I can·figure·that or not. ·It's a factory GM speed sensor buffer from·like 85& up·Trans-Am/Camaro, so it depends if I can find out what the·components that are on it are. It's a solid state unit, but I'll work on that now.
Joe
Post Edited (jknightandkarr) : 4/28/2010 12:14:51 PM GMT
6758 H
CS 8609 H
on it & one large yellow component with 336K printed on it. I tried to look for scematics on the net, but no luck. It's a 4000 Pulse per mile to the speedometer & 2000 ppm to the cruise control, & unknown value to the ecm, 4K again I think. My book don't tell this value. This is about all the info I can give at this time. on the Buffer
Joe
What voltage levels does the buffer output ? I hope you are not running 12V pulses directly into a propeller pin ??? That would be bad.
You will probably need a filter between the buffer output and the propeller pin. Maybe just a resistor and a cap would do it.
Bean
Joe
Lots of propeller based products in stock at affordable prices.
Free shipping on orders over $100 and a Free LCD screen for orders over $200. Today Only(April 28th, 2010)
propmodule.com will be closed May 1-10th. Orders made in that time will be shipped on the 11th.
