Keypad DTMF program
Hey everyone! I now present to you my Keypad(3x4) DTMF program which will make all the sounds you hear when pressing regular phone key numbers. It also displays the number/symbol pressed on the parallax serial terminal. The program is self-explanatory and is commented well. Enjoy!
"The man who smiles when things go wrong has thought of someone to blame it on."
-Lucky[size=-1][/size]
spin
10K
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
"Wow! Can it dial the phone? This is what I've been waiting for for years!!!! :-D"
Just so you know, dial the phone at your own risk.
Nyamekye,
Unfortunately, they're not too cheap, normally somewhere between $10 and $30, depending on the features and other specs...
UC Berkeley '12 EECS
CalSol: UC Berkeley Solar Car
http://calsol.berkeley.edu
KJ6AWU
Just be careful. Usually the blue pair of wires is the only wires in use inside a telephone cable but the other wires can be in use if you have more then 1 line. the 2 wires in each pair are called the tip and ring. The ring wire will be sitting at -48V. however if some one calls you a 90VAC signal gets modulated over that line while the ringer is going off. These voltages can be dangerous and trust me the 90VAC hurts.
Lots of propeller based products in stock at affordable prices.
Free shipping on orders over $100 and a Free LCD screen for orders over $200. Today Only(April 28th, 2010)
propmodule.com will be closed May 1-10th. Orders made in that time will be shipped on the 11th.
