Fastest way to charge a super cap?
I would like to charge a cap to 5V as quickly as possible from a 24V battery.
My thought was to use a 3A switching regulator to get down to 5V
Use a 3ohm 1W resister in series with the 0.33F cap.
This resister would be over spec for a bit:
0.0s: 800%
0.2s 560%
0.4s 370%
0.6s 250%
0.8s 170%
1.0s 110%
Could the resister handel this abuse for such a short time?
Now if I placed a 0.82ohm resister with a poly switch set to trip at 2.5A it would start to conduct after 0.9s from the start causing the cap to reach 4.5V at about the 1.5s mark
This scheme would cost about $2 not including voltage regulator. Any problems with it? suggestions for better solution? Keeping in mind space and money is in short supply.
Lots of propeller based products in stock at affordable prices.
0.0s: 800%
0.2s 560%
0.4s 370%
0.6s 250%
0.8s 170%
1.0s 110%
Whats the internal resistance of the Caps?
I think Phils approach is a good option, though I have to admit I've used a 5w resistor to limit the charge current. I'm not proud of that.
You need to check the failure modes for the particular cap you have in mind, but in general supercap failures are benign. "venting" or going open circuit, unlike big electros. Have a read here
What is the failure mode of a supercapacitor?
If a supercapacitor is exposed to excessive voltage or temperature for extended periods it gradually degrades to essentially an open circuit. The time taken for this to occur depends on how much over voltage or over temperature is applied. Other than physically puncturing the supercapacitor there are no short circuit failure modes. There are no catastrophic failure modes.
from www.cap-xx.com/resources/faq.htm
raising the power supply voltage to 5.7V and using a schematic like this:
would definetly be fastest though.
With either constant current charge, or charge via a higher than 5V (which due to the internal resistance tends to approximate constant current charge) there had better be a good cutout mechanism when it is charged at 5V.
I wouldn't be game to do this at all. I'd be using a constant voltage 5V regulator and a dropping resistor.
There may not be a need to use a 3A switcher. If you have a standard 7805 rated at 1A, and an internal resistance of 30R, the most current that will ever flow is 1/6th of an amp (5/30). So there is no point having a regulator that can supply more than this. So this saves some money too. Bog standard 7805 and if you like, maybe a protection resistor 10R or something in series.
www.smarthome.viviti.com/propeller
I have a few super caps lying around that I can abuse so I will try placing one on a power supply with a tiny fuse to see if the current draw from empty will exceed the predictable current draw from the internal resistance.
