115200 baud works with faster system clock speed?
I've noticed that if I use the following system clock settings (using object FullDuplexSerialPlus.spin, Parallax Serial Terminal, Parallax USB to serial, and 5MHz crystal), that I will get "gobbledygook" on the terminal at baud rate 115200.
But·the following·will work fine at baud rate 57600...
· _xinfreq = 5_000_000····················
· _clkmode = xtal1 + pll1x
If I use these system clock speed settings or faster...
· _clkmode = xtal1 + pll2x
...it will work fine at 115200.
Are there certain clock speeds I should use for faster baud rates?
From your description it looks like the clock must be about 80 times faster than the baud rate.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
