PropellerRobotControlerBoard + PWM with 2 Motors
nomad
Ref: PRCBoard + PWM························
hi,
i have a chassis with 2 motors and the PRCB and 12volt Battery
and i want drive this two motors with PWM (PWM_32_v2.spin)
the original-code is from botdocter as attachmend-file.
now today i make first a little test with this code
forward-movements are ok but...
- backward (reverse)
- leftTurn
- rightTurn
dont work??? nothing moves and i dont know what i should do
few questions:
1) is this correct:
here some code snippets what i mean, is this correct???
I think, if i change the directions, i must make stop for the motors before i take a
another directions ?
for help, hints and tips is appreciated
regards nomad
Post Edited (nomad) : 4/28/2010 7:29:41 AM GMT
hi,
- leftTurn
- rightTurn
few questions:
1) is this correct:
- interns Pins are
- LeftMotor MOT_A
- chipPin P24,P25:
- outa[noparse][[/noparse]24] := 0 Left Motor Stop
- outa[noparse][[/noparse]24] := 1 Left Motor Reverse
- outa[noparse][[/noparse]25] := 0 Left Motor Stop
- outa[noparse][[/noparse]25] := 1 Left Motor Forward
- RightMotor MOT_B
- chipPin P26,P27:
- outa[noparse][[/noparse]26] := 0 ' Right Motor Stop
- outa[noparse][[/noparse]26] := 1 ' Right Motor Forward
- outa[noparse][[/noparse]27] := 0 ' Right Motor Stop
- outa[noparse][[/noparse]27] := 1 ' Right Motor Reverse
2) Forward:
- leftMotor:
- PWM.Duty(25,50,16_665) '
- rightMotor
- PWM.Duty(26,50,16_665)
3) Stop
- leftMotor:
- PWM.Duty(25,0,16_665)
- rightMotor:
- PWM.Duty(26,0,16_665)
4) LeftTurn (lefMot = reverse, rightMot = forward
- leftMot:
- PWM.Duty(24,50,16_665) ' reverse leftMot
- rightMot:
- PWM.Duty(26,50,16_665) ' forward rightMot
5) RightTurn (leftMot = forward, righMot = reverse
- leftMot:
- PWM.Duty(25,50,16_665) ' forward leftMot
- rightMot
- PWM.Duty(27,50,16_665) ' reverse rightMot
6) Backward
- leftMot:
- rightMot:
regards nomad
If yes:
You should write the code as in the example in the top of the file.
it is something like:
IF range < 30 'cm
Turnleft
or turnright or whatever
so you need the sensor input to make it do something.
If you want to drive the robot by remote, that's another thing. I don't know much about, but there should be enough on the forum. Also i believe the Stingray demo code( with ping))) ) has code build in for the remote. Just google for it.
If you need any more help i need some more information like wat you exactly want the bot to do.
Botdoctor,
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
